Sponsored by: Auxito
Lights
Old May 5, 2007 | 10:49 PM
Moyerboy's Avatar
Moyerboy
Lights
I have a big problem i was driving my truck and i lost my cluster lights my parking lights everything but my high and low beams no trailer lights not door lights (LEDS in the door handles) i had turn signals and brake lights thats it can som1 please help me
Old May 5, 2007 | 10:59 PM
screwy's Avatar
screwy
Dumb question, have you checked the fuses?
Old May 5, 2007 | 11:05 PM
Moyerboy's Avatar
Moyerboy
yes and there all good not 1 is bad
Old May 5, 2007 | 11:26 PM
screwy's Avatar
screwy
Including the ones under the hood? Sorry, you’d be surprised how many people don’t know about those. When you press the lock button on your key fob, when it honks do the parking lights flash?
Old May 6, 2007 | 10:35 AM
Moyerboy's Avatar
Moyerboy
i even checked under the hood and when i hit the lock button the lights go out and my parking lights dont flash anymore either the lights will stay on until u hit the lock then they go off
Old May 6, 2007 | 10:37 AM
rsylvstr's Avatar
rsylvstr
make sure you press the LOCK button on the fob twice to see this.
Old May 6, 2007 | 11:10 AM
screwy's Avatar
screwy
Ok, I’m going to go ahead and assume that you have Auto lamps as well. If you don’t have parking lights when you use the switch, auto lamps or the key fob, then there are only two things, the fuse and wiring. Since you’ve checked the fuses, do you have a voltmeter to start checking the wires?
Old May 6, 2007 | 11:31 AM
Moyerboy's Avatar
Moyerboy
some were i have one and i don t have auto lights and when i push the lock button on the fob the horn honks and the head lights flash but there are no longer parking lights when i do this
Old May 6, 2007 | 11:43 AM
screwy's Avatar
screwy
Ok, well pull the light switch out of the dash and disconnect it. Hold the harness plug so the clip is facing up and measure the voltage between the ground and the 2nd wire in from the left on the bottom row. Should be tan with a white stripe.
Old May 6, 2007 | 04:06 PM
Moyerboy's Avatar
Moyerboy
ok ill check and then ill let you know
