Sponsored by: Real Truck
Axle code missing! What should it be?
Old Dec 12, 2019 | 02:36 PM
RenoHuskerDu's Avatar
RenoHuskerDu
I found a 2000 F350 cclb dually for a parts truck. The axle code is blank on the DOT sticker. I hate it when Ford does that. Should I expect it's probably a 373 or a 355?
It's in another state.
The drivetrain will be for @calvinhg OBS, so I'm hoping it's 3:55. But because it's DRW, I suspect that 373 was the stock ratio.
Old Dec 12, 2019 | 03:51 PM
Just Strokin's Avatar
Just Strokin
have you looked for a tag on the rear axle housing cover? There is usually a metal tag under one of the bolts.
Old Dec 12, 2019 | 04:44 PM
RenoHuskerDu
Got a pic of the axle tag but can't find a source to decode YC35. It appears to be 4.10 LS, might be a Dana 80.
606263-2 might be where it's built and when?
What do you think?
Old Dec 12, 2019 | 06:41 PM
Just Strokin
4.10 indicates thee gear ratio. I suspect it is a Sterling 10.5" rear.
If it were a locker, it would be 4L10.
You can compare the cover to these and determine the model of the axle.
Old Dec 14, 2019 | 09:05 AM
RenoHuskerDu
SNIP
I don't believe that Ford ever used the Sterling in a dual rear wheel application. It's in another state so I can't crawl under there and have a look, but I think it's probably a Dana 80.
Sb1911
Jul 2, 2019 10:55 PM
George84
Mar 21, 2012 09:06 PM
60RatRod
Aug 14, 2010 09:36 PM
Ultraboy
Jan 16, 2006 07:14 PM
gingerbreadmaniac
Apr 26, 2005 09:17 PM
