cold blooded EFI
Old Oct 11, 2003 | 11:53 AM
ssap108's Avatar
ssap108
cold blooded EFI
when i start my truck cold it only idles fast (1200rpm) for about 5 seconds than down to 750, normally i expect that it should idle fast for at least 30 to 60 seconds, allowing the engine to warm up some. this makes my truck "cold blooded" even stalling some times. i have no codes(only "11") or check engine light. is there anyway of controlling this? also what acts as the "choke" on fuel injection? thanks in advance. steve
1990 f350 460 4x4 CC
Old Oct 11, 2003 | 09:17 PM
LxMan1's Avatar
LxMan1
The water temp sensor in the intake( not the single wire gauge sending unit, the 2 wire sending unit in a water jacket) tells the computer if the engine is cold or warm. It could be faulty.
There is also a air charge temp sensor in the intake track somewhere, probably in and intake port on the manifold, that senses the air temp being drawn into the engine.
Check for vacuum leaks, if the truck has a mass-air sensor, clean it. I would also check the IAC (Idle Air Control) motor. It could be sluggish. You can try cleaning the inside( the two holes where the plunger is ). Sometimes you can get lucky, but Usually, replacing it is better.
If this doesn't fix it, then I would try replacing the water temp sensor.
Jimmy
Jimmy
Old Oct 11, 2003 | 11:37 PM
ssap108's Avatar
ssap108
jimmy, maybe the temp sending unit is faulty, sending a "warm" signal all the time.makes sense.i'll check these items tommorow. thanks for your input steve
Old Oct 11, 2003 | 11:40 PM
LxMan1's Avatar
LxMan1
No problem
Jimmy
191124x7
Nov 19, 2016 08:41 PM
thuvard
Jul 11, 2016 11:51 PM
bigslurrp
Mar 13, 2013 09:32 PM
imfox
Alaska Chapter
40
Dec 22, 2008 03:15 PM
MagKarl
Dec 2, 2008 11:02 AM
