Alternator parasitic draw?
Old Dec 11, 2019 | 07:40 AM
SamT's Avatar
SamT
So I’ve been hunting a draw that will drain my battery hammer dead over night. I have noticed that my voltage indicator doesn’t seem to act right, almost like it’s not charging at low rpm and it goes crazy when you rev it up over 2000.
Also if you jump the thing and let the alternator charge the battery it will die if it's idling, rev it some and something smells like melting plastic. Swap the alt and move on?
Old Dec 11, 2019 | 10:03 AM
mary-kate's Avatar
mary-kate
I think you said this truck sat for a while. Sitting is hell on alternators because their case is vented, moisture and corrosion take their toll on the internals. Of course, the easiest way to troubleshoot the alternator is to unhook all the wires on it while leaving a charged battery connected overnight. If it starts the next morning you know it's the alternator, and it's already half taken off. It does sound like your alternator is bad.
The melting plastic smell is (likely) either a malfunctioning alternator regulator (plastic rectangle on the back of the alternator), or the fusible links heating up while trying to charge a dead battery. My '94 F250 has two grey forty amp fuse-links in parallel on the alternator charge wire. They connect at the fender solenoid where the positive battery cable bolts to the same solenoid. Charging a dead battery with the alternator is hard on everything.
Batteries can short out internally and drain themselves. It's uncommon, but not rare where they'll charge up and act normal for a while, but if they sit they will die.
If you replace the alternator make sure you charge the battery all the way with a charger or take it to Wal-Mart or a parts store and they'll charge it for you. They can also test it if you're at all uncertain of the battery's condition. If you take in your alternator or get a junkyard alternator the parts places can test it too. That way you eliminate these components as problems if an electrical malfunction persists.
Also - Please don't take these basic instructions as an insult. I don't know if you know this stuff or not. I often take for granted that not everyone has a multi-meter and battery charger and knows how to use them, so I err on the side of caution and say a lot of simple stuff. Don't get overwhelmed either - the charging system on these trucks is relatively simple and the factory wiring is stout.
Rugratt69
16
Mar 14, 2019 11:07 PM
Calheader
Nov 19, 2014 02:30 PM
Deadsquiggles
1978 - 1996 Big Bronco
Jul 8, 2014 09:30 PM
dragonslayer
Electrical Systems/Wiring
Feb 5, 2007 10:46 PM
skyhawk1
1997 - 2003 F150
Jun 18, 2006 06:16 PM
