Alt,/ Battery
Old Feb 2, 2007 | 02:57 PM
dragonslayer's Avatar
dragonslayer
Alt,/ Battery
Having charging problem. `94 F-150 5.8L 140 amp alternator. The battery keeps
draining and will not charge back up. Any info on fixing problem.
Old Feb 2, 2007 | 05:32 PM
Franklin2's Avatar
Franklin2
Get the truck started, and take a voltage reading at the battery. Report back with the reading.
Old Feb 2, 2007 | 07:50 PM
Bluegrass 7's Avatar
Bluegrass 7
Alternator has a bad diode stack and the regulator may be bad at the same time.
Fix it right or it will just hound you.
Test for drain. If you see it, unhook the alternator charge lead. If it goes away, it's alternator time.
Old Feb 5, 2007 | 09:18 PM
dragonslayer
Took the positive off and the truck died. Took it off and went to local alternator repair shop and tested it. There is a couple of diodes that were bad so having it rebuilt. It was only putting out 10.3
Old Feb 5, 2007 | 09:19 PM
dragonslayer
Oh, and I have to change out my Positive cables.
Old Feb 5, 2007 | 10:46 PM
Franklin2's Avatar
Franklin2
Just trying to get the message out. Taking the battery cable off with the engine running can be a bad idea. The battery holds the voltage down if the alternator is in a failure mode were it is running out of control.
