Computer Chips & Tuners
Install Process
Old Oct 11, 2003 | 10:19 AM
true4.2's Avatar
true4.2
Install Process
Ok, I've never done a thing to any Ford truck ever. In the past I'd always worked on Chevy's. I've never installed any kind of chip on any truck. Here's what I need to know:
1.) Where is the computer? I guess I could check my manual, but if you guys could give me a quick answer, it would save trouble.
2.) The Diable chip comes with the switch, so where would be a good place to mount it?
3.) Do you have to unhook your battery ends while you are installing it?
4.) Do you have to unhook your fuses or a certain fuse before you install it?
5.) Is the Diablo chip a direct replacement for the other chip, or is it a "piggy back" chip that goes onto the back of the original chip?
6.) Is it just an easy plug 'n' go task?
Thanks for any help you guys can give me! I look forward to the chip in the future! I'm guessing the chip itself would come with directions on installation, but I may be wrong. I'm kinda impatient.
True4.2
Old Oct 11, 2003 | 10:31 AM
FTE Ken's Avatar
FTE Ken
Re: Install Process
[QUOTE]Originally posted by true4.2
[B]Ok, I've never done a thing to any Ford truck ever. In the past I'd always worked on Chevy's. I've never installed any kind of chip on any truck. Here's what I need to know:
1. Behind the passenger side kick panel. Silver/grey colored box.
2. Ash tray or under the bottom edge of the dash.
3. Yes.
4. No.
5. Neither. There is a service port on the side of the computer box. Its not really a chip, but a add-on board that plugs into the service port.
6. Yes.
Yes, it will have full instructions along with photos.
Old Oct 11, 2003 | 07:47 PM
true4.2's Avatar
true4.2
Ken,
Thanks for your input. I plan on ordering one within the next month or two as well as the intake.
Old Oct 16, 2003 | 09:45 AM
true4.2's Avatar
true4.2
Hey, I'm assuming by passenger kick panel you mean the fold down panel that you would store your manual or whatever in? I took that off and found a bunch of metal hardware. What am I missing?
Old Oct 21, 2003 | 11:58 PM
FTE Ken's Avatar
FTE Ken
No, that's not the kick panel. The panel is the panel that your foot kicks. Its the plastic panel to the right of your feet on the passenger side and to the left of your feet on the drivers side.
Don't worry about the installation. Its really easy, doesn't require any advance knowledge of the locations, procedure, etc. We include full instructions with step by step photos. Its really a simple job. I've had house-wives install them as Christmas surprises, I'm sure you can handle it.
Old Oct 22, 2003 | 07:56 PM
true4.2's Avatar
true4.2
HAAAHAA!!! ahhh, that's where it is...boy I feel dumb. Thanks a million Ken!
640 CI Aluminum FORD
Apr 23, 2011 04:55 AM
bigtimebubba
85
Apr 30, 2008 04:43 PM
bigtimebubba
Apr 24, 2008 11:38 PM
true4.2
21
Dec 16, 2003 07:11 PM
tbomb
Sep 22, 2001 04:51 PM
