Auto Start Stop Question / Confirmation
Old Dec 9, 2019 | 08:21 PM
Jonesy0027's Avatar
Jonesy0027
Howdy Fellas,
Today I realized my trucks auto start stop function only shuts off the engine at a complete stop when my heater blower is set to ‘vent’.
When the heater blower is set to ‘defrost’, the engine will NOT shut off at a complete stop.
I don’t think it’s a problem, just how the system functions.
Please let me know if you’re truck functions the same. Appreciate your input.
Old Dec 9, 2019 | 08:26 PM
scott91370's Avatar
scott91370
More than likely since the a/c runs in the defrost position it keeps the engine running. But I bet the section on Auto Start/Stop in the owners manual will tell you for ure.
Old Dec 9, 2019 | 09:44 PM
smokewagun's Avatar
smokewagun
I doubt the “A/C” function is the switch keeping the truck running, but I’d bet dollars to donuts the “defrost” being a safety issue (you can’t see out frosty windows or if the windshield is icing) that keeps it running. I have the *** permanently disabled, so I can’t confirm defrost, but *** will operate with the A/C on and heat, depending on other variables.
Old Dec 9, 2019 | 10:42 PM
TJReams's Avatar
TJReams
It won't let the engine shut off on max defrost or max ac. It will not shut off the engine, if the engine temp is not satisfied, interior temp is not satisfied, or if the trans is in neutral or manual shift mode. Not counting Trailer tow or Sport mode. It is in the manual.
Old Dec 9, 2019 | 10:52 PM
ford390gashog's Avatar
ford390gashog
The gauge display will tell you the reason the engine stayed on for that cycle. The cluster will display " Engine On - Low Temperature ", " Outside Temperature ", " Charging " and so forth.
Old Dec 11, 2019 | 01:22 AM
ArthurLaurent's Avatar
ArthurLaurent
My Auto Start-Stop function had stopped (2018 F150 Lariat 3.0-L PowerStroke Diesel 4WD with most of the bells & whistles and 18K miles.). Not that I even noticed; I thought the truck just hadn't (ever) warmed up. Last night, I got a message on my dash that the Start-Stop was disabled because of inverter use. I had plugged in a Motorola charger for my HT way back at the end of June; even though there was no battery charging in it, the charger was still "on" enough to draw current from the inverter. Just in case you want another way to bypass you Auto Start-Stop... Arthur
Old Dec 11, 2019 | 08:20 PM
lwk362393's Avatar
lwk362393
It's funny, after reading this thread I paid a bit more attention while driving my truck tonight and noticed that it DID shut off at a stop light even when I had the defroster on. I only had it set to defrost (but not the max defrost setting), no vent, and sure enough the auto stop/start activated. I was a bit surprised actually because it's cold here in MA tonight, mid 20s, and the truck wasn't up to operating temperature yet. The heat kept blowing while it was off, as far as I could tell. I'm guessing it only won't shut off when MAX defrost or A/C is on, presumably because it has to run the blower/compressor a lot harder. Just my $0.02.
Old Dec 12, 2019 | 03:21 PM
GlueGuy's Avatar
GlueGuy
IIRC running defrost will run the AC compressor to dry the air. So I don't know what combination would defeat the A.S.S.
James Wade
Aug 9, 2018 10:35 AM
ian.barsch
2015 - 2020 F150
17
Sep 21, 2016 11:46 AM
Apocalypse
Feb 8, 2016 08:49 PM
strongjm25
Oct 10, 2010 11:49 AM
jasfaa
Aug 31, 2008 02:04 PM
