Sync 3.4 Update How To.
#46
OK I am starting over and re down load the files for USB 2 from Tricon link above, now i am not sure i need the .LST file on my USB or on my USB inside the SyncMyRide folder with all the other files.
sorry for all the post I am usually very good at this stuff and im turning a 30 min job into an all nighter.
Make sure the Sync folder has the same files as the USB2 file on Tricons upload
#47
got it, doing it now.
#48
I had done the same thing an was using 1 USB stick to do the upgrade..
After it completed an I got threw looking around with it the she said was around 2am..
I paid for it the next morning tho as I needed to be up around 7ish,thank goodness I was able too pass that one
down the line..
#52
BREAK
Any of you smart guys come across a reformat utility to enable a rollback to 3.0? The upgrade has broken my Fuel Prices app within Travel Link.
#54
No going back now.
Perhaps Ford will roll out this update next year for more vehicles.
#55
#56
But formatting is formatting. If you format it one way, you can format it another. We're just talking about organizing digits here. All you need is the correct tool, not unlike the formatting tool included to enable the move to 3.4.
#57
@hdzrt1SD250 I sent you a PM.
All is good now, lessons learned
1. Be sure to get a clean download of all files
2. After unzipping files check that complete file extension show tar.gz (In windows 10 you need to check box that says show file extensions)
3. Double check that all files you load on USB are correct files
Do it right and the update takes about 30 min, after you download files - unzip files - load files to USB
Thank you all for your help
#58
Received 6,841 Likes
on
#59
I appreciate your admonishment (extremely helpful post too).
damn you’re still having this issue? Go back to 3.3, you’ve already done the format 3.3 works. Next time I drive my truck I’ll take a picture and send it to you. To show you it’s working on 3.3
ill also admit you use more features than most of us. I use the gas price app on my phone.
