Timer Pointer Installation Problem
Old Dec 9, 2019 | 06:13 AM
acdc's Avatar
acdc
Talking Timer Pointer Installation Problem
96 F150 Eddie Bauer 5.8 L
Had the engine replaced couple years ago
Had to replace the distributor
Went to set the timing and there was no timing pointer!!
Ordered one and went to install it.
The crankshaft sensor is in the way and both won't bolt on at the same time.
One or the other can be bolted on but not both
Any suggestions or solutions would be much appreciated
Old Dec 9, 2019 | 06:02 PM
Conanski's Avatar
Conanski
Bring #1 piston to TDC on the compression stroke and then look at the balancer and I bet you will see the timing pointer, if not then you know what one you need to buy.
Redworks
Jul 16, 2015 03:55 PM
iwals
Nov 21, 2010 10:52 AM
mrfix71
Jun 23, 2007 08:52 PM
skelator
May 23, 2004 10:22 AM
dwebb210
Dec 10, 2002 10:58 AM
