Cold weather idle
Old Dec 8, 2019 | 12:44 PM
relicdog's Avatar
relicdog
Cold weather idle
2003 7.3 when truck was new,in cold weather it would start an idle at normal rpms then ramp up to fast idle after a couple minutes now after replacing injector cups, o-rings, seals, glow plugs both wire harnesses an gaskets the idle starts at different rpm’s according to the temp. Outside sometimes high as 900 rpm’s to start then ramp up to high idle after a couple minutes, then slowly decrease rpm’s as truck warms up.Do I have a problem at 900 rpm’s to start an what would be causing such a fast idle at start of engine.
Old Dec 8, 2019 | 05:02 PM
Homerunking2394's Avatar
Homerunking2394
this is due to a high idle set by the computer...normal
fordman19762003
Nov 3, 2019 11:39 AM
Liquid10Rider
6.7L Power Stroke Diesel
Jan 21, 2019 11:07 PM
2000F250guy
Dec 14, 2011 07:45 AM
akorcovelos
Nov 3, 2010 10:30 AM
