Dually rear end
Old Dec 7, 2019 | 07:57 AM
Ron/RPMS's Avatar
Ron/RPMS
Dually rear end
Hey Guys and Gals, I'm looking for a rearend for a 84 f-350 dually. It is a pickup frame and need to have a 4.10 gear.
What am I looking for?
Dana 70?
Dana 71?
What year trucks would I be looking for to fit this truck?
Thanks to any and all replies. Ron.................
Old Dec 7, 2019 | 11:46 AM
Franklin2's Avatar
Franklin2
Your truck originally had a Dana, but I think I would look for a little bit later Ford/Sterling 10.25. So much easier to work on the brakes, you just pull the drum off. On the Dana's you have to pull the axle and then the hub/bearings to work on the brakes. You can look all the way up to 1998. Some of the rearends may have a little different yoke length, so be prepared for the driveshaft to possibly need shortening or lengthening a little bit.
Old Dec 7, 2019 | 06:40 PM
Franklin2's Avatar
Franklin2
Here is a place in Missouri that say they have a dually rearend to fit.
1986
Rear Axle Assembly
Ford Truck F350 7.5,AT,RWD 108,610 A 147926 $500 Griffin Auto Salvage LLC USA-MO(Grovespring) Request_Quote 800-280-1219 / 417-462-3928 Request_Insurance_Quote
Old Dec 7, 2019 | 08:04 PM
Ron/RPMS's Avatar
Ron/RPMS
Franklin 2 thanks for the info, the brakes on the 10.25 would be a welcome addition.I have a couple sources local but I need to know what I'm looking for. I have not heard anything bad about the 10.25 so I would assume its a good part.
Thanks...........
Old Dec 10, 2019 | 04:43 PM
Diesel_Brad's Avatar
Diesel_Brad
Thanks...........
if at all possible get a 92+ sterling axle. it has the long pinion yolk for more support.
Just remember if it is for a pickup, it has to come from a dually pickup. Cab-n-chassis are different
Old Jan 3, 2020 | 06:30 PM
Ron/RPMS's Avatar
Ron/RPMS
Are the later dually rear ends lug centric or hub centric?
Old Jan 3, 2020 | 07:26 PM
Franklin2's Avatar
Franklin2
We had a 89 f350 and it was hub centric. But this will depend also on the wheels you use, and the lug nuts you use.
Old Jan 4, 2020 | 07:53 AM
Diesel_Brad
87+ are hub centric
Old Feb 29, 2020 | 10:00 PM
Ron/RPMS's Avatar
Ron/RPMS
Originally Posted by Diesel_Brad
87+ are hub centric
So if I went with the hub centric rearend I will not be able to use my lug centric wheels?
Thanks
Old Mar 1, 2020 | 07:34 AM
Franklin2's Avatar
Franklin2
Thanks
I have never tried that. But if your lug centric wheel fit over the center protrusion on the rearend, and you used the proper lug centric lug nuts, I don't see why it would not work. I think if I were you I would carefully measure the diameter of the center hole on your lug centric wheels, and then measure the hub diameter on the rearend you are thinking about using. If it fit over the hub, or had clearance around the hub, I would think it would work. You may need something like the picture below to measure the rearend hub.
Old Mar 1, 2020 | 07:44 AM
Diesel_Brad
Thanks
Chances are you can. But you will need to measure your hub and hub hole on the wheels
BWD444
Nov 1, 2017 04:09 PM
jedwa1216
Feb 6, 2015 06:36 AM
7K42S
Aug 23, 2007 03:09 PM
fordguy76
Aug 4, 2006 11:58 AM
karljay
All Things Towing
Dec 24, 2004 01:46 PM
