Highboy
Old Dec 6, 2019 | 05:02 PM
Kubota8626's Avatar
Kubota8626
Highboy
Anyone ever put 351 Cleveland in highboy. And what everyone do to get rid of the ram assists steering
Old Dec 6, 2019 | 05:53 PM
JacobJ's Avatar
JacobJ
installing 78/79 F250 4wd steering box is the way to go. Welding and cutting a little of your cross member is required but its not all that hard. Here are some pictures showing the areas already cut out and the new metal waiting to be welded:
Attachment 282516
Old Dec 7, 2019 | 11:30 AM
Ian Clarke's Avatar
Ian Clarke
are all 78/79’ 4WD steering boxes the same? Is there a 1/2 ton and a 1 ton box?
Old Dec 7, 2019 | 12:07 PM
dwirth's Avatar
dwirth
Here’s what I screen shot when I did mine. Doesn’t give exact info on box tho
Old Dec 7, 2019 | 12:18 PM
Ian Clarke's Avatar
Ian Clarke
ok, thank you!
Old Dec 7, 2019 | 03:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ian Clarke
are all '78/79 4WD steering boxes the same? Is there a 1/2 ton and a 1 ton box?
D9TZ-3504-C (replaced D7TZ-3504-C) .. Ford/Saginaw Integral P/S Gear Box / Obsolete
1977 F250 4WD from serial number Y20,001 (not a High Boy) // 1978/79 F250 4WD // 1979 F350 4WD
Old Dec 7, 2019 | 03:24 PM
1TonBasecamp's Avatar
1TonBasecamp
The F150 steering gearbox is completely different from the F250/350 box.
Not sure which one is better suited, but Jacob's conversion came out very clean. Was more work I think than he lets on about, but that's because he works his way through obstacles very quickly!
The 150/Bronco box mounts outside the frame rails, has a "standard" style pitman arm that faces forward and attaches to a long draglink that runs over to the passenger side.
The box is easily converted to "rear steer" where you can put the pitman arm facing rearward if that would work better. We do that on the Early Broncos all the time and it's referred to as the "4x4x2" box because you take the input section from a 2wd Ford gearbox and put it together with the 4wd box and sector shaft bits. Instant reverse-steer!
The 250/350 box mounts inside the frame rail, has the more unique pitman arm that faces outward to the driver's side and attaches via a short draglink to a "steering arm" bolted to the top of the steering knuckle.
Paul
cumminshighboy
Oct 14, 2015 11:24 PM
jbouknight
Jan 10, 2012 10:10 AM
78_f150
Nov 17, 2011 11:14 AM
bartn98
Dec 20, 2008 10:32 AM
