Help w/89F150
Old Jan 2, 2020 | 07:54 AM
Justin2912's Avatar
Justin2912
Will the code reader I use for my 89 also work on my 2008?
Old Jan 2, 2020 | 08:07 AM
My4Fordtrucks's Avatar
My4Fordtrucks
No. They are completely different systems and the diagnostic connector is different. I use an Actron CP9125 on my OBD-II vehicles to retrieve codes.
Old Jan 2, 2020 | 08:35 AM
rla2005's Avatar
rla2005
As previously stated...no the OBD-I reader for your 1989 truck will not work on your 2008 OBD-II. My first ELM327 based reader was a BAFX 3127. It works well with FORScan and Torque. If you want a reader that has capabilities to read more than basic drivetrain codes then consider an OBDLink 426101 ScanTool MX Bluetooth. A little more pricey, but it can communicate to more of the modules installed on these modern vehicles. This device also works very well with Torque/Pro and FORScan if you have an android device.There are others that work with a PC.
Right now I suggest stopping by a parts store then have them run the code check for you. Get the codes then list them in a new thread on the proper forum.
Old Jan 2, 2020 | 09:25 AM
Justin2912's Avatar
Justin2912
10-4 will bring it to Advance and get codes. What is the proper forum? Prob the right year is a place to start I’m assuming.
Old Jan 2, 2020 | 11:18 AM
rla2005's Avatar
rla2005
2004 - 2008 F150
Larrymac52
Aug 21, 2019 08:01 AM
TCounty
1997 - 2003 F150
Feb 1, 2016 09:06 PM
Quicksilvr20
Aug 5, 2013 12:24 PM
GarageSpec
50
Nov 12, 2011 11:52 AM
scootjockey
Modular V8 (4.6L, 5.4L)
May 25, 2009 01:35 AM
