Funny idle
Old Nov 8, 2011 | 06:01 PM
GarageSpec's Avatar
GarageSpec
Funny idle
Its very minor but I noticed today that my truck is idling just a little off. In park Idle is fluctuating at maybe a 100 rpm higher and then going back down. But in D at a light idling it changed a little as well. It seems to be running just fine from my little experience with them. It pulls hard out on the highway. Just wondering if there is anything I should check for, just common stuff. Im paranoid that my engine is gonna mess up, I have dreams about it....no bs
-Rich
Old Nov 8, 2011 | 06:09 PM
GarageSpec's Avatar
GarageSpec
One more thing. When I turn the key off with everything off, it sounds like something is humming....like the speakers for the stereo are one but the volume is turned all the way down. Just something else Ive noticed.
No cel or warning lights of any kind. I did notice this after I ran the truck out of fuel though. (yeah, I did that). I also added Lucas diesel treatment like two days ago. Im just trying to just think of things that could pretain to my prior post. Thanks
-Rich
Old Nov 8, 2011 | 06:26 PM
Action4478's Avatar
Action4478
Inside the fuel res there is a small round opening on the side of the bowl . It is the FPR fuel return screen ..
Look to see if it is clogged with junk .. If it is you can clean it with a Q tip with the fuzzy material removed from the tip ...
Take a look ...
Old Nov 8, 2011 | 07:18 PM
GarageSpec's Avatar
GarageSpec
Ill do that tomorrow at the job. Thanks
Old Nov 8, 2011 | 07:46 PM
fordpride's Avatar
fordpride
Deleted.......
Old Nov 8, 2011 | 07:48 PM
GarageSpec's Avatar
GarageSpec
Originally Posted by fordpride
Also look to see if you have oil in the ICP connection
I dont know what that means. I see you guys talking about it but Im not hip to the jargon.
Old Nov 8, 2011 | 07:54 PM
F350-6's Avatar
F350-6
The ICP is a sensor on the front, inboard side of the drivers head.
Also make sure the oil is full, not over due for a change, and doesn't have any oil additives in it. But I would start by checking the FPR since you ran out of fuel.
Old Nov 8, 2011 | 08:11 PM
GarageSpec's Avatar
GarageSpec
I just changed the engine oil and filter. I havent checked it since its only 500 miles old at most.
So if I pull the sensor the ICP should be full of oil? I feel like it has to be fuel related. How should I check the FPR? Do they have any inline filters or anything? Ill shim it while Im in there I guess. I hope its not injectors.
Another dumb question. At idle, how are these things supposed to idle anyways? Im all stock at the moment. I dont know anyone else with a early 7.3 powerstroke to compare. It doesnt shake, but just rattles away pretty flatly with a faint shake due to the low idle speed. Thats how I can describe mine.
Action4478's Avatar
Action4478
If I would have had the opportunity , I was going to help you , one test at a time so not to over whelm you ...
Check the FPR screen first , its a cheap test . Then unplug the ICP sensor , (look for oil leaking from it )see if the idle improves . If it does , the cheaper of the 2 tests is to replace the ICP sensor . If that doesn't take care of it , the IPR is next .. Much more expensive ..
Old Nov 8, 2011 | 08:15 PM
GarageSpec's Avatar
GarageSpec
Thanks.
Ill clean the FPR filter on the side of the fuel bowl first. Then Ill check the ICP. Hopefully that will do it. Id hate to have to dig any farther with her as Ive just gotten the truck and already put a tranny (which wasnt a bad thing) in it.
Old Nov 8, 2011 | 08:29 PM
Action4478's Avatar
Action4478
Thanks.
If you need additional help & don't want to deal with (some of the)egos here , PM me I'll help you all I can
Old Nov 8, 2011 | 08:33 PM
fordpride's Avatar
fordpride
There you go Rick have your opportunity I will not post on anything that I see you post in. I'm out
Old Nov 8, 2011 | 08:40 PM
Action4478's Avatar
Action4478
Check your PM 's buddy ...
Old Nov 8, 2011 | 08:44 PM
F350-6's Avatar
F350-6
If you're really that upset Rick, go you your user cp and click on the ignore button. Put my name in there and you'll never see me post again.
Old Nov 8, 2011 | 08:54 PM
Action4478's Avatar
Action4478
Must be gang up on Rick night ...
Chris , I have always gotten along with you .. We have welcomed you all along , When any of us try to help up in your section , we are treated like we are invisible .. The Egos there are huge ..
Since you brought it up , it is obvious what you are doing .. & should have been to everyone else ...
If I went to your section & you were in on a thread , I knew the OP was in good hands . You don't offer me the same respect ..
BTW ,, I know how to use the ignore feature ...
