I'll never understand why "cold air" intakes always draw in hot under-hood air. Even more puzzling is that people buy them!
That one has a cover that prevents that. There's others as well that do. Even though, from what I've seen, you get hardly anything out of it until you're up in the higher reaches of the rpm band. Most of us don't drive like that, so the only thing you're gaining is looks and sound.
I can't see much of anything with this package that makes the cost worthwhile, 14hp, and 53 lbs of torque? That's a joke.
Oh, but wait, it does say Roush!!!!!!
Price is definitely high but in the old days, engine mods like cylinder head porting, cams, etc, were all kind of hit and miss and cost a lot of money because you were into the engine.
The Ranger has almost as much torque as the Mustang which means the Ranger is designed to make more power at lower rpm which is more suited for use in, say, a truck.
I'm guessing the Mustang engine would have less pull at 2000 rpm dragging a heavy trailer up a hill. The Ranger also uses features from the Focus RS block which is sturdier than the Mustang block (because that is the most powerful 2.3 EB version), and the Ranger engine has to go through heat and load testing that is much harder than a Mustang engine would be put through. (Does the Mustang have any trailer pull capacity?)
