Stealth or Tunnel Ram?
Old May 17, 2004 | 08:18 AM
Momudder720's Avatar
Momudder720
I've heard all kinds of stuffabout how much better the Stealth is than the performer etc intakes, and was wondering if a tunnel ram with a 4 bbl top would do as well? I know the tunnel rams flow better at higher rpms. I'm not terribly concerned about anything clogging up the air cleaner; I build a shroud deal for the front of it and that works like a champ.
Old May 18, 2004 | 05:15 AM
DeenHylton's Avatar
DeenHylton
Unless your building your truck just for show or dragstrip use only I'd stay away from a tunnel ram. A single-plane or dual-plane manifold will net you more HP and torque almost anywhere below 5000 RPM.
Deen
Old May 18, 2004 | 12:55 PM
proeliator's Avatar
proeliator
Indeed, you'd have a soft lower end with that tunel ram and its the last thing you'd want on a mudder. Stick with the Stealth.
