Heated steering wheel
Old Dec 4, 2019 | 08:38 PM
Xpnsv's Avatar
Xpnsv
Can you use a steering wheel cover on a heated steering wheel
Old Dec 5, 2019 | 04:33 AM
Deuce40s's Avatar
Deuce40s
Yes. But obviously it'll be less effective. You probably won't feel any heat at all.
Old Dec 5, 2019 | 07:53 AM
BlueRidgeMan's Avatar
BlueRidgeMan
If the cover holds the heat ‘in’, I wonder if prolonged use would cause enough heat build up on the steering wheel to damage something?
if you cover the steering wheel, turning on the heat probably would be pointless.
Old Dec 6, 2019 | 10:14 PM
kper05's Avatar
kper05
I think many just remove the cover in the winter then use the cover to reduce wear when a heated steering wheel is pointless.
Maybe a perforated "wheel skin" would allow some heat through and not overheat the steering wheel.
https://wheelskins.com/europerf
Old Dec 8, 2019 | 04:48 PM
The Bone's Avatar
The Bone
If you wear leather gloves that would help keeping the steering wheel nice. I think its the oils in our hands that cause leather to wear out. Buy a spare steering wheel so you can change it out if it starts to bug you.
Old Dec 14, 2019 | 06:28 PM
grantrekker's Avatar
grantrekker
Well then, I sure must have oily, acidic hands. Took delivery Jan '19 of a f450 and by August with 15Kmi, the wheel was abraided and losing finish to the extent that it was a warrany replacement. Maybe I just got a wheel that was cut a bit thin or tanned a bit to much. Warm hands though.
Old Dec 16, 2019 | 07:59 AM
The Bone's Avatar
The Bone
The leather on these steering wheels are thin and not very durable for sure. i think it's a combination of oil and dirt, maybe the soap you use to wash your hands. It could be a number of things causing this. I try to put my hands on different parts of the wheel but i find my hand at the top most of the time. So far mine is ok but kind of shiny. I only have 65,000 so time will tell.
Mixer man
Jul 21, 2017 10:34 AM
odin2
2004 - 2008 F150
Jun 23, 2012 06:21 PM
aerocolorado
Aerostar
Aug 28, 2003 07:42 PM
ranger53
Aerostar
Jul 6, 2001 09:36 AM
