I have already done a 3G alternator upgrade on my 82 F100 4.9 w/AC. Did it several months ago and havent had any issues. However, when I have the heater blower on high with both wipers and lights on, then something squeals more than the fat guy in Deliverance. I know I read about this somewhere before I did the upgrade but now I cant find it. Anyways, can someone point me in the right direction on this? Oh, I should mention it does NOT do it at idle, only when on the gas - even a little.
New belt or old?
If old I would replace it to start then make sure it is tight.
Remember that altanator had a wide serpentine setup so more belt and was pretty tight.
Dave ----
New belt or old?
Remember that alternator had a wide serpentine setup so more belt and was pretty tight.
+1 on that.
You have discovered this new alternator requires more oomph to drive it compared to the stock unit. A single V belt can only transmit so much power. Whenever the alternator requires more power than the V belt can deliver, you will get slippage. There are a few minor things you can do to change the equation, short of converting to a double belt drive. Can't guarantee this will eliminate the squealing completely, but it should decrease it.
1) Get a new drive belt, if you haven't already done so. If the existing one has been squealing on a regular basis, it will be glazed over.
2) Make sure the belt tension is correct.
3) Try some belt dressing. I've had good luck with this stuff to stop minor squealing. Here's one brand, Permatex #80073. This or an equivalent should be available at any auto parts store:
4) Have your battery load tested to make sure it is in good condition and fully charged. If it won't hold a full charge, your poor alternator will be working extra hard to keep the voltage up. It would be like to trying to blow up a balloon with a hole in it. Reduce the electrical load and this will make it easier on the drive belt.
thanks all, I will def try new belts (2 v belts) and let you know how it goes
Oh, I didn't see that you already had a dual belt setup.
If at all possible, get new belts from the same batch. You might find some sort of batch number or date code. Otherwise, if one belt was just a smidge longer than the other, the tighter one will end up trying to carry most of the load.
What else is driven by the two alternator belts? On my 3g I have the water pump and alternator on dual belts. With the belts pretty tight it will squeal on startup and for the first minute or two if the battery is near dead but works fine 99% of the time. I have a switch in the dash so I can turn on the alternator after startup.
I know its been a while. Since the weather is cooperating and I'm stuck at home, I put on new belts and no more pig squealing lol. Also finally got around to upgrading the headlight wiring harness with one from LMC.
