Cooling System Flow
Old Dec 3, 2019 | 03:11 PM
arthall's Avatar
arthall
Cooling System Flow
I have a '53 F-100 with an 8BA flathead V8. Am I correct in thinking that the direction of system flow is from the bottom of the radiator to the 2 pumps, into the block and up through the heads, out the thermostat housing and into the top of the radiator ? This would put the temperature sensitive side of the thermostat reaching below the base of the thermostat housing and into the heads.
Old Dec 3, 2019 | 06:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Your description of system flow is correct. Thermostats are always marked "TO RAD" on the appropriate side.
acl9865
Mar 11, 2017 02:06 PM
Eric Kropp
Jun 25, 2016 08:32 AM
faststang94
Bronco II
Jun 22, 2007 01:10 AM
blueball ranger
1983 - 2012 Ranger & B-Series
Dec 5, 2005 07:11 PM
dkchristensen
Aug 1, 2003 12:05 PM
