remote start range?
Old Dec 2, 2019 | 04:06 PM
hdman6's Avatar
hdman6
Unhappy remote start range?
i have a question for you fellows you have the factory remote state as I do. I bought a 2019 F250 6.7 crew cab in Sept. Came with factory remote start. I never had remote start but wife told me I will like it in the winter etc. I was in the sticker build already so it did not matter anyway. So it seems the range is really short. maybe 25 feet or less. I have change batteries and tried them both. Today at work i was withing 10 feet and then the lock and remote start worked. Big deal, right ? why bother having it and paying for it if you have to be right on top of the truck to use it. Anyone else have this issue? just checking to see if it needs to go to dealer under warranty for this .... thanks Jeff
Old Dec 2, 2019 | 04:23 PM
TeddyD's Avatar
TeddyD
Something is really wrong with your remote start range. I get about 500 feet. It lowers if I’m in a building and can’t see the vehicle and increases in the wide open.
Old Dec 2, 2019 | 04:29 PM
hdman6's Avatar
hdman6
i am going to try new Duracell batteries first if that dose not help i will go to dealer. My "new batteries" have been in my desk for a while so they are questionable. thanks
Old Dec 2, 2019 | 04:36 PM
hondomurph's Avatar
hondomurph
Hi Jeff , I would say something is very wrong . My 2019 f350 can be started from inside the house and the truck is inside a metal garage about 100' from the back door . I also can start it when I am on the opposite side of the parking lot at a Walmart Supercenter .
Old Dec 2, 2019 | 04:45 PM
BOSS 379's Avatar
BOSS 379
Do you have the FordPass app and modem in the truck? If so you can use the app to start the truck.
Old Dec 2, 2019 | 04:51 PM
Macdsl's Avatar
Macdsl
My truck got to be terribly short range all of a sudden, same as what you are describing it would only work if I was almost on top of the truck. Bought new lithium battery and now back to usual, as others have said these actually have very impressive range for the stock remote fob.
Old Dec 2, 2019 | 05:09 PM
JHForman812's Avatar
JHForman812
the ford pass app lets you start it without needing the remote, and the remote start can run longer. you can continue to extend it in the app. don't remember the last time I used the fob to remote start. oh and you can do it from anywhere !!
Old Dec 2, 2019 | 05:12 PM
98ramtough's Avatar
98ramtough
You have to pay to have the ford pass remote start right? I have ford pass but in my 2018 platinum it doesnt give that option.
Old Dec 2, 2019 | 05:26 PM
BOSS 379's Avatar
BOSS 379
I didn’t have to pay anything separate, but it might require Sync3 to get the modem (not 100% sure).
Old Dec 2, 2019 | 05:42 PM
BOSS 379's Avatar
BOSS 379
https://owner.ford.com/fordpass/ford...c-connect.html
Check out the section that indicates which models may have it.
Old Dec 2, 2019 | 05:56 PM
jbjones85's Avatar
jbjones85
my range is pretty decent, can’t say exact footage but will remote start from the house our to the street if I happen to park there (~50-75’) and from my offie to the parking lot (~100-150’).
Old Dec 2, 2019 | 06:26 PM
mtnguy's Avatar
mtnguy
Originally Posted by hondomurph
My 2019 f350 can be started from inside the house and the truck is inside a metal garage about 100' from the back door.
Same scenario with my 2017.
Old Dec 2, 2019 | 06:31 PM
Lamoon78's Avatar
Lamoon78
The remote works like others stated from a very good distance. The Ford app is even better. I was at work over 350 miles away truck was at home told my wife to let me know when she was going to crank it up cause I wanted to see if it would work that far fired right up.
Old Dec 2, 2019 | 07:55 PM
mispohr's Avatar
mispohr
I have same issue any reason why? Dealer said it's normal but it's not
Old Dec 2, 2019 | 08:29 PM
Knoxp's Avatar
Knoxp
I could never figure out the app. I have a 2019 XLT with Sync 3. I down loaded the app, but it never went beyond the basic vehicle stats.
I wish there was a surefire way to know if it had a modem.
