93 f150 stalling
Old Dec 2, 2019 | 10:23 AM
jzmcpherson's Avatar
jzmcpherson
93 f150 stalling
Hello all new here
so on my 93 f150 2x4 ,5.0
it has been stalling while driving until it warms up after a out 5 min of driving.
then does it slightly but driveable.
Checked no codes.
things already done.
new Autolite plugs ,wires, cap, an rotor button
new IAC valve and TPS
I put a new map sensor on and it really got bad to drive where it would stall or buck very bad everytime you give it some gas
Hard to drive so reinstareinsold one runs better but still stalls until warm
ordered and installed a new map sensor again same thing
It cuts our bad upon giving it gas almost to the point of shutting off then takes off like a bat out of ....
any ideals on this please help
Old Dec 2, 2019 | 12:02 PM
88n94's Avatar
88n94
Try replacing the coolant temperature sensor. Don't confuse this with the temperature gauge sending unit.
Old Dec 2, 2019 | 12:50 PM
jzmcpherson
Coolant sensor
Opps my bad yes the coolant sensor for ecm was replaced as well as new MSD oil
Old Dec 2, 2019 | 02:22 PM
jzmcpherson
Stalling f150
I was also mainly wondering why 2 different Map sensors acted exactly the same and worse than with original
Old Dec 3, 2019 | 12:25 PM
ryman's Avatar
ryman
o2 works only when warmer?check for power to heater circuit.
95singlecabSam
Jul 4, 2019 09:11 PM
annaleigh
Jan 20, 2018 09:59 PM
roughridn_sob
Dec 9, 2014 07:25 PM
Clubwagonman
Apr 15, 2009 10:54 AM
