Good morning everyone. I bought a 1965 F100 last weekend and noticed the shift selector is off 1 gear. N mark is actually Drive, etc. The truck used to be manual but is a C4 automatic now.
I read a few posts about adjusting linkage but Im new to this and cant visualize it.
Can this be adjusted on the column?
If not can someone post a picture of what I should adjust below on the linkage?
One thing to consider first - is the column out of a 1965 or 1966 that originally had an automatic or is the column from a newer vehicle?
The column is held to the underneath side of the dash using a bracket that is welded on, so while you can alter the up and down position using that bracket some it doesn't allow a person to rotate the column. There is some adjustment typically in the one rod that connects to the transmission, so you might be able to alter that some. The adjustment procedure is in the shop manual under MANUAL LINKAGE ADJUSTMENTS.
Yes I believe the column is from a 1972. At the tranny connection would I need to go up with the nut or lower it some to match it up correctly?
Here is a page from the 69 shop manual. If your shift rod is slotted instead of threaded it still works the same. The later manuals say to hang a 1 lb. weight on the shifter to make sure it is against the detent when you adjust it. If whoever put that transmission in there used all truck parts everything should line up perfectly. But if after you adjust it and it is still not lining up you may have the wrong manual lever in the transmission. There are people on here all the time with shifter problems because someone put a car transmission in a truck without putting a truck manual lever in the trans.
Ok, that makes sense. I think it is from a Mustang, so that may be the issue. Thank you for that info. So if I do try to adjust this, I should lengthen the rod, so it can reach the correct mark, right?
Trans should have an ID tag on the intermediate servo cover. 64-66 C4s had dual-range or “green dot” shift pattern valve bodies.
In 67 Ford changed the shift pattern to the conventional D-2-1 pattern valve body.
The 64-66 valve body, if placed in the first detent past N would start off in 2nd gear (2-3 up shift.) The second detent past N would start off in 1st gear (1-2-3 up shift.) The 3rd detent past N is low gear only.
1966 C6s had dual-range valve bodies, also. Changing to the D-2-1 shift pattern in 67.
Just do the steps in the page I posted. ( Manual linkage Adjustment)
Step #4 says to adjust the rod - you'll just want to follow the directions. I didn't provide the directions because I didn't want to answer any questions about written directions from someone else. Lol.
I worked on this a few hours today and whether I go up or down, I cant get more 2 gears to line up on the column. It seems to need to shift wider from the pivot point. If it is a shift linkage from a Mustang is this what happens?
Also where can I find the correct linkage for the 65 F100 to mate with a c4 automatic? I will also need the bushing as its falling apart.
You need to identify what you have and go from there.
Trans ID tag is on the intermediate servo cover.
What does the shift arm on your trans look like?
Trans ID tag is on the intermediate servo cover. What does the shift arm on your trans look like?
Thank you for this, will take a pic of this later. Hope I still have the tag!
While you're under there take a picture of the manual lever on that transmission. You said it came from a Mustang, I don't remember any Mustangs with a column shifter. If the manual lever in that transmission is for a floor shifter it ain't never going to work with a column shifter. There should be an ID number stamped on it, see if you can make out what it is.
