Black Stuff Under Hood
Old Dec 1, 2019 | 02:19 PM
lynnmor's Avatar
lynnmor
I wonder if others have observed this stuff. I can't tell where it is coming from, one would think road dirt but it is coal black and I don't think that I have driven on roads that would cause this. When touching other surfaces nearby, I don't find much black stuff. The black aligns with openings at the top in front of the radiator. Could it be exhaust circling back to the front of the radiator? 2011, 6.7, 55,000 miles.
Black Stuff
Old Dec 1, 2019 | 04:46 PM
Just Strokin's Avatar
Just Strokin
just first thought is road grime. Have you been following any vehicle that is using oil or losing oil/gear lube Or maybe from a semi? Does it have any smell? Or does it feel oily?
Old Dec 1, 2019 | 06:11 PM
lynnmor's Avatar
lynnmor
It feels a bit oily. No, I have not followed a vehicle blowing anything, the truck is clean as can be.
Old Dec 1, 2019 | 06:33 PM
senix's Avatar
senix
does not appear to be from your truck. Wash it off and watch. Unless you see something obvious I would say another vehicle you were following.
Old Dec 2, 2019 | 12:14 AM
Mwmx54's Avatar
Mwmx54
Geez, do you maybe idle a lot? And have an exhaust leak? I’d also bet it’s from another vehicle, or something other than your truck.
On a side note, has anyone noticed the paint being rubbed completely off in the area of the black stuff on that hood? Where the rubber seal along the radiator rubs the hood? Mines wearing A groove into the aluminum. I’ve considered a strip of clear vinyl, like used for paint protection on hoods and bumpers. But curious if my hood is just moving around a lot, or if it’s normal.
Old Dec 2, 2019 | 05:04 AM
senix's Avatar
senix
no movement in my 2013.
Old Dec 4, 2019 | 03:20 PM
69cj's Avatar
69cj
I would definitely check my air filter and see if it matches the hood. My bet would be that it does. I also don't believe that it's from your truck.
dirthawg
All Things Towing
Mar 19, 2018 12:23 PM
Rick Cargo
Appearance & Dress-Up
Nov 6, 2012 02:03 AM
pkenn7
Mar 20, 2011 11:35 AM
nghtrgr
Paint & Bodywork
Jan 5, 2008 09:07 PM
bobzilla67
2004 - 2008 F150
21
Apr 28, 2004 11:10 PM
