Power fold Mirrors
Power fold Mirrors
My 2016 F350 with power fold mirrors is messing up they will randomly fold in and out. Has anyone had this happen and may know what the fix is? Truck is out of warranty so don't really want to take it to the dealer if I can fix it myself I'm pretty mechanically inclined.
Mine folded in once when I was adjusting them when driving. I discovered that they will fold in while driving. What happened is I adjusted the passenger mirror. When I was switching over to the driver side I happen to hit a bump at that exact time and it caused me to jog the switch back which folded the mirrors. I thought about contacting Ford as this could be a safety issue not having an interlock to disable while not in park or neutral.
Are you you inadvertently bumping the switch if you are resting your arm on the sill?
Not touching anything when it happens. Truck was sitting in the drive way and watched it do it. It has also done it so much over night that it at killed the batteries on the truck. I have unplugged the switch for now to see if it still does it but don't think it is the switch causing it I think there is a short somewhere at this point or a module has gone bad.
GulfcoastSD
Dec 4, 2011 08:16 PM
Din
Sep 1, 2010 11:15 AM
