Deleting EBV
Old Nov 28, 2019 | 09:20 PM
PNWstroker's Avatar
PNWstroker
Deleting EBV
Hey guys, my EBV is leaking oil and I’m ditching it. My question to you guys are what parts should I replace while I’m right there. The pedestal obviously, and I will replace any seals/gaskets that are in there. But anything else while it’s torn apart? Pipes? Also does brand really matter on a part like this? I’d also take any tricks/tips on the process. Thank you!
Old Nov 28, 2019 | 09:53 PM
aklim's Avatar
aklim
https://prosourcediesel.com/shop/for...RoCW1gQAvD_BwE
https://shop.fullforcediesel.com/ebpv-delete-kit but I would do the up pipes
Old Nov 29, 2019 | 08:51 AM
jimjokjv's Avatar
jimjokjv
Pedestal and the install kit.
Old Nov 29, 2019 | 09:09 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Riffraff and Diesel-o-rings are site sponsors and have everything you need.
In addition to the pedestal, you should at least install bellowed up-pipes if you have not already. I installed the Dorman variety, but many go for the International pipes.
Take a close look at the turbo when it is out, it might need a refresh/rebuild. Some last for 500,000 and some do not.
Do a boost leak test when you put everything together, it is easy and cheap and will allow you to keep the power where you want it.
Old Nov 29, 2019 | 10:03 AM
Brian Hanks's Avatar
Brian Hanks
I did all that is described plus got some billet plenum inserts and new boots clamps. Can do as many or few as want on boots and clamps. At this time only did the plenum ones.
my up pipes were leaking terrible too.
also rebuilt turbo and put high flow
outlet on. Used xdp bellowed up pipes and also put in a riff raff wheel..
Sous
15
Aug 7, 2018 02:17 PM
That_Guy
Apr 10, 2008 10:22 AM
Duck Hunter81
Jan 8, 2008 05:45 PM
ron's power stroke
Apr 30, 2007 02:42 AM
dzjammer
Jun 29, 2006 04:07 PM
