LONG TRIP QUESTION
Old Nov 28, 2019 | 05:35 PM
RA101725's Avatar
RA101725
Banned
Personally I would stick to the interstate and stay off the two lane stuff this time of year for safety reasons especially once you’ve got the trailer on. Better cell phone coverage and more services if you get in a pinch. I have family in Albuquerque and they got a foot of snow yesterday so running further down south may not be any guarantee of an easier time. Don’t use the cruise control if you get into any slippery stuff.
Old Nov 28, 2019 | 05:42 PM
Of The Tower's Avatar
Of The Tower
hmm, alright then. Yeah I was planning on riding the interstate the whole way through anyways. It could possibly be a hit or a miss. But I think I’d be more comfortable driving in the snow on flat surface vs driving through the Rockies because of my inexperience with the mountain terrain/range. But thanks for the heads up and info!
Old Nov 28, 2019 | 06:34 PM
Tedster9's Avatar
Tedster9
New Mexican interstate crosses the continental divide at (7,200 ft) but it ain't anything like Colorado. I avoid driving on I-70 Colorado whenever I get the chance, have done it many many times. It's OK when roads are clear and dry, but when the weather is skosh or nighttime, no thanks. Figure about 160 miles - from Denver to Glenwood Springs, is twisty, high mountain passes and steep grades. Don't get me wrong, it's beautiful, but...
Old Nov 28, 2019 | 07:09 PM
helifixer's Avatar
helifixer
ADOT is talking about shutting down 160 miles of I40 tonight, from US93 to Winslow due to several feet of snow forecast and high winds, you know I70 through the Rockies won't be nice either. check weather before you go.
Old Nov 28, 2019 | 07:21 PM
z31freakify's Avatar
z31freakify
IMO a spare ICP, IPR miscelanious fuses and relays. Unplug the fuel bowl heater just in case. Tools and quick disconnect tool. Make sure you have a jack, tool to remove the wheel nuts, and the sapre is road worthy in case you have a blow out.
Old Nov 28, 2019 | 08:37 PM
RA101725's Avatar
RA101725
Banned
Spare tire and complete jack kit, yes. Torque wrench that goes high enough for lug nuts is not a bad idea but the tire iron will work in a pinch. A tow strap and a couple D-rings is also not a bad idea.
Old Nov 28, 2019 | 10:07 PM
Of The Tower
Yepp NM it is!!! Colorado is for the summer time for sure tho. Need a vacation lol. Thanks for the info!
Old Nov 28, 2019 | 10:09 PM
Of The Tower
will do!!! Thanks!
Old Nov 28, 2019 | 10:10 PM
Of The Tower
for sure!!! Wrote down this and everyone else’s suggestions thanks for the input!
Old Nov 28, 2019 | 10:11 PM
Of The Tower
for sure! Missing a couple items but will add to the toolbox in the bed, thanks!
Old Nov 28, 2019 | 10:17 PM
Wes444's Avatar
Wes444
Like others have mentioned its not necessarily the truck's age you need to be worried about this time of year. Assuming of course you keep up with it's maintenance. Like Sous' trip mileage we tow a 5th wheel from Oklahoma to Cali & back during the summer, usually stopping thru national parks in not so on the way states. Between 5 and 9k miles round trip depending on the route
Carry spare Motorcraft CPS, IPR & ICP if you can swing it; pretty much in that order of importance. An extra gallon of oil and 3 qts of ATF, gallon of coolant, 5gal of diesel, and an assortment of tools and you should be good for most common hiccups. Check the spare tire's age and pressure. Make sure none of your coolant hoses are cracked at the ends. Do a boost leak test on your intercooler pipes, change oil & the fuel filter if it's needed b4 ya get back milage wise. Make sure the trans and diff fluids are topped off. And check the darn air filter.
Vehicle prep will be key. Weather can't always be predicted, but its better to be prepared for a 6 foot blizzard and be pleasantly surprised if its only an inch or two of snow. Basics like heavy blankets in the cab, snacks for 2 days and water are nice insurance.
Old Nov 28, 2019 | 10:31 PM
Of The Tower
i definitely keep up with maintenance. Want her to last as long as possible. Just did everything possible to my knowledge. Fresh trans flush. Front and rear diff drained and refilled. Transfer case drained and refilled. And of course the oil. New air and fuel filter. The spare is old and has some age cracks on the side of it so I definitely need to get a new one. That I did forget. And as for the other stuff. I’ll definitely bring with me. I leave next weekend. So I’ll be prepared for sure. I appreciate your tips! And everyone else’s. People on this forum are amazing. Especially since this is my first post. Much appreciated.
Old Nov 29, 2019 | 01:04 AM
  #28
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
How fresh are the brakes? If the linings are thin they might not make it.
For fluids include a fuel additive to prevent gelling overnight.
Got a pic to share of the 68? I had a 65 and a 75 dent side, but never a bump side.
Old Nov 29, 2019 | 05:50 AM
  #29
Wes444's Avatar
Wes444
On the subject of the spare, make sure your jack is tall enough to lift the truck off the ground, and in the worst case scenario lift the max axle rating weight. Even my 4 ton floor jack made me wish i had a 6 ton when i blew out the rear tire towing the 5th wheel. And i say check the jack's height, because my first flat was less than a month after i bought the truck, and the dealer included jack ran out of travel 1/4" shy of reaching the lowest part of the axle on my stock height 4x4 when i was in Mexico
Old Nov 29, 2019 | 06:23 AM
  #30
jdw1's Avatar
jdw1
You’re the only one that knows your truck and how it’s be cared for!
One more thing to think about on your return trip, if you should take the southern route home and the weather gets cold up north, make sure your fuel is prepared for cold weather, if you unplug your fuel bowl heater like someone mentioned you could be setting yourself up for some issues.
Jmo
fyi, I towed a trailer to Spokane Washington and back from Minnesota this summer with my 2000 Excursion, it has 326’xxx miles on it, no problems!
