Starter kill switch question
Old Nov 27, 2019 | 01:18 PM
StrokinHer01's Avatar
StrokinHer01
I have a momentary toggle switch interrupting my starter.. is a 60 amp switch ok or should I put in a relay with it?? It doesn’t have constant current going through it. The reason I’m asking is can it cause a fire for some reason not using a relay? Also how many amps travel through the solenoid wire??
Old Nov 27, 2019 | 01:55 PM
woodnthings's Avatar
woodnthings
Your 2001 should have a starter solenoid on the passenger fender. I take it you have modified the typical starter circuit and eliminated this? A solenoid is always the best route as you trigger the solenoid with small gauge wire in lieu of having larger gauge wire running all over.
See below for the Starter No Load Test. It says no more than 170 Amps for a starter that is not loaded. So 60 amp's is not near enough.
Starter Motor — No-Load Test
1. Connect a fully charged battery to the starter.
2. Connect the Alternator, Regulator, Battery and Starter Tester (ARBST) as illustrated.
3. Connect a remote starter switch between the starter solenoid Terminal S and the positive battery
terminal post.
4. Press the remote starter switch. The pinion should shift to the crank position and the motor should run
smoothly.
5. While the starter motor is running, record the voltmeter and ammeter readings.
6. The voltage reading should be greater than 11.0 volts and the amperage should be no more than 170
amps.
7. If voltage is lower than specified or amperage is higher than specified, refer to the results chart below
to determine possible cause and corrective action.
Old Nov 27, 2019 | 02:31 PM
SteveH-CO's Avatar
SteveH-CO
If you're making an anti-theft device (and you don't have to reveal that here), it's better to interrupt the solenoid wire, which only draws 1-2 amps (to hold in the switch). Interrupting the starter feed wire is not a great idea (as woodandthings said). yes - a dedicated/smart thief can figure out how to jumper the '01 solenoid and still steal the truck, so this is not a perfect solution.
For the record, I don't see how an unloaded starter could possibly draw 170 amps, unless that was the inrush current just as it starts spinning.
Old Nov 27, 2019 | 03:08 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
You might look at this..
https://www.ravelco.com/
Yes its pricey...but its the only thing I trust. It was put to the test this past winter unfortunately. Paid for itself that night.
Old Nov 27, 2019 | 06:49 PM
Wes444's Avatar
Wes444
Or a Cyclops relay on the IDM / PCM slot
Old Nov 27, 2019 | 07:16 PM
StrokinHer01
Pretty sure I tapped into the 12 gauge wire
Old Nov 27, 2019 | 11:11 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
SpringerPop has a sleek, but elaborate, engine disabler.
Old Nov 28, 2019 | 12:06 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The problem with disabling the starter is that the thief will look for a switch. A mechanically inclined thief that knows our trucks can start the truck, even if the starter is disabled.
The IDM or fuel pump are much more effective ways if disabling your engine.
Old Nov 29, 2019 | 08:23 AM
StrokinHer01
I’ve got that switch somewhere it would take days to find.. I might integrate a fuel cut off switch also.
court1100f
18
Apr 9, 2014 11:22 PM
bayslayer
Dec 5, 2011 04:26 PM
savag
Feb 19, 2011 03:11 PM
ralbach
Jul 18, 2009 08:24 AM
yolbolsom
Mar 10, 2003 07:27 PM
