Prime fuel pump?
Old Nov 26, 2019 | 07:16 PM
LVExp's Avatar
LVExp
Prime fuel pump?
I accidentally ran my 1965 F100 i6 300 out of gas and now i can't get it started again after putting gas in.
I removed the fuel line from the carb, no gas. I removed the fuel filter and it was empty. Left the filter off and turned it over, no gas. I then tried with and without the gas cap to avoid any venting issues.
I'm still new to carborated engines, what am i missing about priming a mechanical fuel pump? It is vertical with the filter on the top of the pump so i don't know how i would fill the filter.
Any input is appreciated!
Old Nov 26, 2019 | 07:22 PM
LVExp's Avatar
LVExp
I searched for an hour before posting but i guess my Google foo isn't working today cause i just found this previous post that i will attempt.
https://www.ford-trucks.com/forums/1...fuel-pump.html
Old Nov 26, 2019 | 07:29 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Run a piece of hose from fuel pump inlet and drop it in a jug of gas. This will tell you which way to look for problem. There is often a lot of gunk in 50 year old gas tanks so my guess is the line to fuel pump is clogged.
Old Nov 27, 2019 | 09:52 AM
LVExp's Avatar
LVExp
Tried running from a gas tank with no luck.
Tracked it back and the fuel pump wasn't creating any suction, replaced the pump ands started right up.
Old Nov 27, 2019 | 12:45 PM
User 71024's Avatar
User 71024
I'd add an inline filter before the pump, just in case the old one sucked up some crap from the tank.
Old Jul 15, 2022 | 08:56 PM
julianfisher's Avatar
julianfisher
7th Gear
Solved
As I suspected the eccentric was the problem. The tab was broken off and the bolt holding it and the cam sprocket was loose. Good news is I got my timing chain and gears replaced so I should be good until the next rebuild. I also found a crack in the water pump. It wasn’t leaking, but I will replace it none the less. Parts showed up today so time to put it back together!
Broken tab on eccentric
Tab still sitting in the drive hole of cam timing sprocket.
danman223
May 23, 2018 05:53 AM
TexasTrash
May 15, 2013 10:29 PM
keyul
May 15, 2011 10:38 AM
brad1982f250
Nov 20, 2009 05:50 PM
jonesn
Dec 30, 2002 01:08 PM
