PHP HYDRA FIXED* Review ****
Old Nov 26, 2019 | 06:11 PM
Offshore_Outlaw's Avatar
Offshore_Outlaw
Installed a hydra today, I was very careful with cleaning the contacts just a tinge of copper showing through plenty of silver left, was sure I had the right hex code..triple checked it.
Installed the idm back into the truck ran my wires all nice and neat no pinched wires etc...
turn the key on...and it pops PP HH 00 and will not start ...remove the chip still won’t start. Need some ideas.
Old Nov 26, 2019 | 06:17 PM
AllaboutMPG's Avatar
AllaboutMPG
Did you have the key off while removing and installing?
Double check that the connector for the pcm in the engine bay is seated properly.
Old Nov 26, 2019 | 06:22 PM
Offshore_Outlaw
key was 100% off
engine connector was good and tight....
I just pulled it out again let see what’s going on
Old Nov 26, 2019 | 06:38 PM
Wes444's Avatar
Wes444
Is that the no start tune?
Old Nov 26, 2019 | 06:46 PM
Offshore_Outlaw
Here is the code conversion, I use the one in red correct ?
also the contacts and hex code on the chip match what decoder says.
Old Nov 26, 2019 | 06:48 PM
Offshore_Outlaw
wont start on any tune
any number, ship plugged in or unplugged
Old Nov 26, 2019 | 07:17 PM
Offshore_Outlaw
Installed again, same issue
no start....wts comes on
I push in the clutch and tune the key
that radio turns off and everything like it normally would but nothing happens at all
Old Nov 26, 2019 | 07:23 PM
AllaboutMPG
So the starter won't even engage? That sounds more like something got dislodged while you were doing the chip install not a pcm problem. Not sure where the wiring is for the clutch switch but would check that
Old Nov 26, 2019 | 07:27 PM
Offshore_Outlaw
so, I did I pulled the harness out of the top of neutral safety switch and the wire on pin 2 connector was loose AF, and messing around the clutch pedal must have knocked out of contact so I jumped it together and viola it started....so disaster averted
thanks for the replies
Old Nov 26, 2019 | 07:28 PM
AllaboutMPG
Let us know how the new Hydra works out
Old Nov 26, 2019 | 08:12 PM
Offshore_Outlaw
Ok so went on about a 15 mile drive aaaaaand I gotta say...I’m not thoroughly impressed....
here’s why
it feels like all the power is between 1k-2200
it just falls on its face after that
now I usually always shift right around 24-2500
And I’ve tried about 6 different settings and they all honestly feel the same.
The go pedal is SUPER TOUCHY, almost like nothing and then bam all at once....
I have an edge cs2 and I always left it on #2 and it was smooth and pulled all the way through 2500
anyone have any ideas
Old Nov 26, 2019 | 08:20 PM
AllaboutMPG
Who's tunes are you running. With the manual tranny you may to try something different
Old Nov 26, 2019 | 08:22 PM
Offshore_Outlaw
just loaded the factory tunes from hydras flash updater thing. I haven’t paid for any custom tunes yet
cleatus12r's Avatar
cleatus12r
Butt-Head
The settings shouldn't feel the same. There should be a noticeable difference between the lower HP and higher HP ones. As much as I HATE to have you do this.....the 140 should smoke like a tire fire from 1000 RPM when you stand on it.
Old Nov 26, 2019 | 08:25 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
If the display lights up, you shouldn't have contact issues. HOWEVER, I still see some coating on a couple of contacts (the two rightmost ones in the top picture and also the rightmost one in the second picture.
