2010 f150 4wd automatic
Old Nov 25, 2019 | 11:40 PM
woodalllm's Avatar
woodalllm
What would cause the 4wd kick in while driving? When you take off down the road and make a turn either way, the 4wd kicks in automatically, even though it's not put in 4wd. Have checked everything I know that might be causing it and still no luck. Thanks
Old Nov 26, 2019 | 06:41 PM
steve(ill)'s Avatar
steve(ill)
two things happen on the 4 x 4... electric motor on transfer case engages the front drive shaft... and vacuum pistons at each front wheel lock the axle shafts to the wheel hub....I assume what you have is the front wheels engaging by loss of vacuum... the front IWE ( vacuum pistons) are normally enaged in 4 x 4 with the motor off... when you start the motor, the vacuum pulls them OUT and you go into 2 x 4... If you change throttle positions "take off down the road", the vacuum can drop and possibly engage the front wheels. I will post a link so you can read more..
Old Nov 26, 2019 | 06:45 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/8...then-some.html
Old Nov 27, 2019 | 12:23 AM
woodalllm's Avatar
woodalllm
Thank you Steve(ill) for your reply. I have checked the actuators on the hub and they are ok. I thought it might be the check valve, replaced that and it still didn't help. Did get new vacuum lines and going to replace them and see if that's the problem. If not, guess the transfer case/motor will be the next thing to check. I sure hope it's not the transfer case
Old Nov 27, 2019 | 04:47 PM
steve(ill)'s Avatar
steve(ill)
if the transfer case engaged, and the wheel hubs did NOT, then you probably would not know it.... I assume the 4 x 4 "kicking in" ment you could hear or feel the front end engage.......
you should go thru the REPAIR and TEST steps in the IWE write up to verify that you actually have VACUUM.
Old Nov 27, 2019 | 05:40 PM
woodalllm's Avatar
woodalllm
Yes have vacuum, it's at about 18-19, both sides. New vacuum lines didn't help, problem still exists.
Old Nov 27, 2019 | 08:27 PM
steve(ill)'s Avatar
steve(ill)
so why do you think the 4 x 4 is engaging ? What are the symptoms.... sound... feel... vibration ?
Old Nov 30, 2019 | 07:30 PM
meborder's Avatar
meborder
Do You have a Trac-loc (limited slip) rear differential?
sticky clutches in a LSD can feel much like something going on in the 4wd
Old Dec 1, 2019 | 01:47 PM
steve(ill)'s Avatar
steve(ill)
that's a good point since he said it happens when you turn corners !!
Crd16
1997 - 2003 F150
Aug 19, 2016 03:41 PM
strat875
Modular V8 (4.6L, 5.4L)
Nov 28, 2015 10:12 PM
srgntrbt
2004 - 2008 F150
Apr 21, 2011 08:20 AM
KYFord
Offroad & 4x4
Jan 20, 2004 02:08 PM
rberghef
Feb 21, 2003 09:37 AM
