fuel pump Q
Old Nov 25, 2019 | 09:50 PM
ColtPNW's Avatar
ColtPNW
fuel pump Q
I've got a 73 f100, previous owner claimed it had a 400 engine in it. and I purchased a fuel pump today. the spot where it mounts to the block is correct but the ports for the fuel lines are angled different, is this going to cause issues or is it fine ?
Old Nov 26, 2019 | 10:23 AM
Tedster9's Avatar
Tedster9
Welcome to FTE
The location of inlet and outlet fittings doesn't matter except, you'll have to maybe bend new fuel line up. NAPA sells "brake line" that bends up really nice for this with fittings pre-installed and flared. I don't particularly care for any rubber hose in fuel line around the engine except as where originally used by the factory for vibration relief and engine movement. Too many places to leak or fail because of modern gasoline. Fuel-injection rated hose I'm told is much better.
It's important to check fuel pump pressure output even with or especially with a new manufacture fuel pump, they are notorious these days for being defective right out of the box. A mechanic's vacuum gauge (which you should have) will test fuel pump pressure. If it is not within spec, take it back and try another pump. If it is within spec then check the "wet height" in the carburetor fuel bowl with the engine shut down after running at idle for a few minutes.
65f600
Large Truck
Nov 12, 2019 07:14 PM
Niveyinc
Sep 8, 2017 10:10 PM
Jbert50021
Nov 1, 2015 10:23 PM
Buyerz
Mar 23, 2014 10:57 AM
gthbryce
18
Oct 2, 2009 06:08 AM
