You shouldn't have to do the relearn just to clear the warning. Just bring the cold tire pressure back up to spec, then drive them around for a few minutes. Within 10 minutes max (of driving around) it should clear.
that's what i thought but it's been almost a week and the tire pressures are back to 55. Maybe my tuner has to reset it.
In colder more northern climates each fall we remove the summer air and install winter air. In thee spring, we reverse the process. That eliminates pesky electronic problems. Plus the tires ride better and it improves the mpg.
I got tired of dealing with the crappy TPMS and ruining wheels. I'm on my third set of leakers. I turned TPMS off and my new wheels will not have the sensors. Getting installed tomorrow. No more corrosion problems!!
