My 2014 6.7 doesn't have a card, there is a place to plug it in though. Tried to find some info on it but was unsuccessful. Do I just have to buy a card and plug it in?
Thanks in advance,
Steve
Reason: Not enough info
You are posting in the 6.7l forum which is for 2011+ trucks but your profile states you have a 2000 F250. What year is your truck? Also does your truck have navigation and that is why you are looking for an SD Card?
If you have NAV, it would give you a message that the Map SD card is missing. You can use FORScan to turn NAV on and and then acquire a Map SD card off eBay. You should be able to search in this forum for NAV to find out how to turn it on with FORSCan.
Thanks in advance,
Steve
You may have better luck in the Super Duty truck forum than in the 6.7 PSD engine forum for this question. Although I have noticed non-engine topics seem to be popular here...
