Common issues with punched out cats?
Haha, you've got a point but then again I don't rev my truck. I'm not a big fan of glass packs so do you know any good flow master mufflers? I'll check with some friends to see what they're running on their trucks.
I see the error in which I worded that response. I'm well aware as to how they work I was just curious if it would give me an issue because it can't get the proper reading of the level of oxygen in the exhaust since it was just a y pipe and converted to long tubes with a full exhaust. In the end though, it doesn't really matter about my question above because I'm probably going to run a better flowing y pipe and have side exit with either a flow master or thrush muffler. If I'm real lucky and I've got people I know running straight pipes then I'll do the same.
So I finally had a chance to work Saturday on removing the exhaust. I left cats on as there's no need to remove them. Sometime in the afternoon on Sunday I went out and purchased the pipes for the truck. I got to work on it at about 4:00 and finished at about 4:45, to me that's good time when it comes to getting the piping to fit and get an exhaust hanger setup by cutting some angle iron and bending the hanger. When I get back home today I will take some pictures of what I've done. The only downside is I don't have my mig welder with me at the moment. I will sadly braze all of the piping together, which will take a good amount of time this evening.
EDIT: the exhaust is not near as loud as I thought it would be. It's just right for a straight pipe. I'll upload a startup and it running on YouTube sometime this week hopefully, this depends on how long it takes to braze.
