Sponsored by: Real Truck
4x4 not working
Old Nov 19, 2019 | 02:59 PM
Pfloyd's Avatar
Pfloyd
4x4 not working
I have a 2006 Ford F250 4x4 and the 4x4 stopped engaging when we switch it in the cab, we checked the actuator motor, switch & relays and they all tested good. What's weird is that we can get it to switch when we go through the scanner without issue but we get nothing with the switch. If we hadn't tested the switch I would have said that was the problem but testing it with the computer it comes back as good. Any suggestions or pointers for what to look at?
Old Nov 19, 2019 | 03:20 PM
speakerfritz's Avatar
speakerfritz
had this problem once and the issue has a crack in the sleeve of the **** that slides onto the shaft. when you turn the ****, the crack opens and the **** turns but the shaft does not.
the fix was to pull the **** and trick it open so the crack opens,,,then put a bit of super glue in the crack with a straight pin.
or just replace the ****
Stebs
1997 - 2003 F150
Mar 3, 2013 07:30 AM
einsteindog
Jan 22, 2009 02:51 PM
Caleb1
15
May 13, 2008 03:18 AM
MintFord
Dec 23, 2006 07:57 PM
PW01
1983 - 2012 Ranger & B-Series
Jul 7, 2006 07:04 AM
