Suggestions needed
Old Nov 19, 2019 | 01:56 PM
ynot321AB1's Avatar
ynot321AB1
Suggestions needed
Am working on a 239 and TRYING to take the water pump off the right side,( as if sitting in the seat) and I can feel the bolt inside the bottom radiator hose and I feel the ridges but when I put a socket on it, it just spins. It does not feel like it is rounded off. Any suggestions as to how to proceed would be apricated.
The one on the right side came loose right off.
Old Nov 19, 2019 | 02:07 PM
Old F1's Avatar
Old F1
Not much of a suggestion, ... but you might be able to see the problem (better) with a (mechanics) mirror ?
Old Nov 19, 2019 | 02:10 PM
bigwin56f100's Avatar
bigwin56f100
Are you at least using a 6 point socket?
Old Nov 19, 2019 | 05:09 PM
ynot321AB1's Avatar
ynot321AB1
Thank you but can it it very well and see all the ridges but for some reason will not break
Old Nov 19, 2019 | 05:11 PM
ynot321AB1's Avatar
ynot321AB1
Am using a 6 point socket and have tried an impact wrench without result, but thanks for the info.
Old Nov 19, 2019 | 05:21 PM
seaves46's Avatar
seaves46
If it's the last bolt try getting a screw driver in behind the pump , then try loosening the bolt while applying slight pressure to separate the pump from the block .
The threads on the bolt may be toast .
Old Nov 19, 2019 | 08:56 PM
ynot321AB1's Avatar
ynot321AB1
Thank you, hadn't thought of that. I will try it.
Old Nov 19, 2019 | 09:28 PM
bobj49f2's Avatar
bobj49f2
If that doesn't work you'll probably have to get in there with a drill and drill it out. Not the best way but it might be the only way. Start with a small drill bit, us a lot of oil and progress to a larger bit that is slightly smaller the inside diameter of the inner part of the thread.
Even if you can drill it so you can break off the head at least you'll get a better look at the remainder of the bolt after you get the pump off.
Old Nov 20, 2019 | 11:22 AM
rico56's Avatar
rico56
Or try to apply some heat (hot air fan) and try again after it cooled down.
Old Nov 20, 2019 | 12:39 PM
F250Rob's Avatar
F250Rob
I'd try putting heat on it before getting out the drill.
Old Nov 20, 2019 | 02:28 PM
bobj49f2's Avatar
bobj49f2
Sounds to me like the threads corroded and fell away from tge main body of the bolt but not enough to allow the bolt to slide out. No amount of heat is going to get that out.
Old Nov 25, 2019 | 01:36 PM
petemcl's Avatar
petemcl
There are lots of bolt extractors out there. Everyone has their favorite(s). Heat and Kroil have worked best for me but that bolt is in an awkward spot and too much heat and you will ruin the water pump.
Your impact wrench is probably what got you in trouble in the first place. 12 point sockets are not good to use on old trucks either. This is a job where you need to feel what is happening.
I have not used this one but it seems to look pretty good and has a good rating. Also not too expensive. Lowes nut and bolt extractor
Old Nov 25, 2019 | 02:28 PM
ynot321AB1's Avatar
ynot321AB1
Got it out
But thanks for the info. I found that the head had been rounded a little,( probably from using the impact) and I found out that a 14mm socket is just a shade smaller than a 9/16 , I jammed it on the bolt and it held long enough to get it off.
Old Nov 25, 2019 | 07:19 PM
F250Rob's Avatar
F250Rob
Nicely done.
josiewales
Apr 23, 2018 03:26 AM
HkyswiM
Apr 9, 2013 10:34 PM
RAMPAGE_F350
Aug 25, 2008 01:18 PM
broncoboke
18
May 23, 2007 10:30 PM
DPhillips
Jul 10, 2004 04:56 PM
