ABS C1095
Old Nov 19, 2019 | 05:28 AM
Turbo1002's Avatar
Turbo1002
ABS C1095
Dealing with a c1095 on a 2006 mountaineer. From the pin point test j it looks like a replacement hcu is needed. Other than the connector it just states bad hcu. Would a donor hcu need the abs module reprogrammed? I see the electronic module can be separated from the pump with a few fastners. What normally goes bad, pump or electronic module? If the old module is installed on a replacement pump assembly would this repair the problem? Can someone help me diagnosis this c1095. I don't have a scanner which can activate the pump, only pull codes.
Thank you.
Jonathan R
Oct 4, 2019 05:57 AM
Wbrann51
Dec 15, 2018 06:18 PM
msnrasool1
May 23, 2018 09:24 AM
Night Rod
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 29, 2011 03:56 PM
JayS
Sep 15, 2006 08:58 PM
