ABS C1095 Code
Old May 23, 2018 | 09:24 AM
msnrasool1's Avatar
msnrasool1
ABS C1095 Code
Hello, I am in need of your help AGAIN. I have 2000 Navigator and week ago, I started the truck and found the ABS pump running not stop. I pull the fuse out to stop the pump from running. After research on the forum, I found this is common issue and most likely ABS module is dead (there were 6 ABS fault codes) . I grab the used abs pump complete assembly from junkyard, pull the module off it and swapped with the truck burned out one. Hookup the scan tool and tried to clear codes, all gone except C1095, Ford manual is asking to replace the EHCU unit. Pump motor was running before and now it don’t. I did found corrosion in the pump motor connector to module. I didn’t clean this because I was out of cleaner spray at that time. I will clean the connector once I get time to get to it. My questions are...
  1. Can I test the ABS pump motor with volt meter and what to look for to determine if it’s dead?
  2. If it’s dead, can I swap the motor out to solve the problem ?
Thank you all.
Jamal
Pocket
Jul 7, 2023 02:50 PM
Rivera1114
Feb 13, 2011 08:39 AM
babe69vw
Nov 1, 2010 04:17 PM
Therapy
1997 - 2003 F150
Dec 14, 2008 08:51 AM
blue&white
1978 - 1996 Big Bronco
Nov 14, 2005 01:25 PM
