Sponsored by: Real Truck
Transmission
Old Nov 18, 2019 | 08:21 PM
Bryon T's Avatar
Bryon T
Transmission
So I replaced front end bushings ball joints oil seals whole 9 , also replaced carrier bearing 2 weeks agoThis past week replaced turbo and pedestal with a free flow down pipe stack onomy 2002 f250 7.3 Aft getting the truck back together took it for a test drive truck has a major shutter which was there before turbo was replaced, but has all kinds of power. Shutter is just during takeoff up to about 15 or 20 miles per hour then at regular running speed Chuck has a slight rumble that stops when you let off the fuel. When I pulled into the driveway yesterday and put it in park to listen to the screech sound coming from torque converter area the truck idle perfect put it in drive and had nothing for transmission would not move, I shut the truck off restarted it and had transmission. This morning I started it to let it warm up, after about 15 minutes got in it to move it had no transmission, same thing shut it off restart have transmission!!!! Somebody had mentioned possibly the ABS or speed sensor may cause transmission to act funny? The turbo was brand-new not rebuilt. Any suggestions any advice please help!!!!!!!
Old Nov 18, 2019 | 08:22 PM
Bryon T's Avatar
Bryon T
I also put new hub assemblies on The run both sides
Old Nov 18, 2019 | 08:24 PM
Bryon T's Avatar
Bryon T
I also put new hub assemblies on The run both sides, and I also replaced up pipes and resonator y
JT250
13
Aug 21, 2013 11:10 PM
hotrodmusic
Dec 31, 2011 02:08 PM
Mark250
Jun 5, 2008 12:12 AM
stockernavstar
Apr 23, 2006 08:38 PM
Saxon
Apr 25, 2005 11:36 PM
