Vacuum Issue
Old Nov 17, 2019 | 04:57 PM
jeremywatco's Avatar
jeremywatco
Vacuum Issue
Hi all,
So I installed a vac assist brake booster from MP Brakes. SUPER easy kit to install and convert.
Only issue I've had, is since doing the conversion when cold my truck idles like crap. If I pump the brakes the truck will just die. Once warmed up it purrs like a kitten. I've tested the vac booster and it has no vacuum leak. Any ideas? Could it be that there is just something else pulling on it and so I need to turn the idle up a little bit?
Thanks, jeremy
Old Nov 18, 2019 | 07:52 AM
Jigs_n_Fixtures's Avatar
Jigs_n_Fixtures
Where did you plumb the vacuum line to the manifold?
Last edited by Jigs_n_Fixtures; Nov 18, 2019 at 07:53 AM. Reason: Autocorrect silliness
Old Nov 25, 2019 | 08:28 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Large vacuum hose should go directly to the intake manifold fitting. Don't tie into PCV system or anything. Check vacuum, you are needing 10" or better. (Ballpark estimate). Use a new check valve.
Old Nov 27, 2019 | 06:53 AM
Rasputin53's Avatar
Rasputin53
Sounds like a vacuum leak. Got a clamp on both ends of the new vacuum line? Did the vac port seal nicely in the intake? Spray some WD40 on the port at the intake end and see if idle suddenly improves for a second.
hillcountryflt
May 2, 2014 09:02 AM
jlynn8403
Jan 19, 2014 08:50 PM
Deviousfred
Jul 14, 2011 12:10 PM
workingdog
13
Nov 17, 2005 08:14 AM
FordandSkeeter
Jan 28, 2005 09:03 AM
