Conflicting head bolt torque sequences
Old Nov 17, 2019 | 10:47 AM
grizbait's Avatar
grizbait
Trailering
Hoping someone can set me straight on head-bolt torque sequences for the 5.4 2V engine. Just had my heads re-built and re-assembling now. I have Fel-pro PermaTorque MLS head gaskets and also bought Fel-pro head bolts - which say updated/re-designed. (they do not have a washer)
Factory Service Manual says torque all head bolts to 30 ft-lbs, in sequence, then 90 degrees, in sequence, then 90 degrees again.
Head bolt package instructions say 27-32 ft-lbs, then 90 degrees, then back out each bolt 1 full turn, then 27-32 ft-lbs and 90 degrees again. This seems counter to the concept of a TTY bolt?
I'm inclined to stick with the factory service manual procedure but if anyone has dealt with this discrepancy I'm interested in input.
Old Nov 17, 2019 | 10:59 AM
alloro's Avatar
alloro
Tell us what the vehicle is so we can check the procedures and TSBs.
Old Nov 17, 2019 | 11:02 AM
grizbait's Avatar
grizbait
Trailering
That would be outstanding, thank you.
2004 Ford Expedition XLT Sport
And it has the Performance Improved head design for what it's worth...
Old Nov 18, 2019 | 09:24 AM
alloro's Avatar
alloro
I cannot find any TSB that supersedes what the FSM says to do. So I would stick with the 30 ft. lbs., 90, 90 sequence.
Old Nov 18, 2019 | 12:21 PM
grizbait's Avatar
grizbait
Trailering
Thank you for checking on that - much appreciated.
Old Nov 19, 2019 | 09:00 AM
alloro's Avatar
alloro
To be more accurate and to avoid overtightening the bolts, don't oil the bolts and then rough up the cylinder head side of the head bolt washers.
Old Nov 19, 2019 | 10:30 AM
the_hetz's Avatar
the_hetz
Why would you not lubricate the bolts? This is common practice.
Old Nov 19, 2019 | 01:18 PM
alloro's Avatar
alloro
You only lube them if the instructions tell you to, otherwise the torque specs are based on the bolts NOT being lubed. Then the reason you rough up the washer is because the smooth surface acts like a bearing which will also affect the accuracy of the torque process.
Old Nov 19, 2019 | 02:02 PM
F350 1990's Avatar
F350 1990
I've done plenty of 5.4Ls (2Vs and 3Vs) the past year and the 2Vs are:
30 ft lbs
90 degrees
90 degrees
Regarding the head bolts: lightly oiled with rag, THEN (mucho important) allowed to drain off PRIOR TO TORQUE'ing.
cookingguy
Nov 29, 2014 10:03 PM
YoungFordAddict66
Feb 9, 2010 02:52 PM
fluidp
Jun 28, 2008 02:56 PM
John - NNY
Flathead V8 & Flathead 6
Apr 26, 2006 08:55 AM
56f600
Dec 21, 2004 10:31 PM
