Message Center Warnings
Old Nov 16, 2019 | 12:27 PM
Justa02TJ's Avatar
Justa02TJ
Over the past 3 days, on 3 different occasions my message center has scrolled through warnings which include “PRE-COLLISION ASSIST NOT AVAILABLE, SERVICE ADVANCE TRAC, and HILL DECENT CONTROL FAULT”. I don’t notice any issue while driving, all seems normal and messages will clear after a restart.
Its its still underway warranty and will be taking to the dealer.
Any similar experiences with this possible gremlin?
Mike
2017 CCSB Lariat Ultimate with all the technical/electrical BS..
Old Nov 16, 2019 | 12:43 PM
HRTKD's Avatar
HRTKD
It could be the electrical gremlin that is due to corrosion in the electrical connectors. Check the connectors between the frame rails, just in front of the rear bumper.'
It could also be a bad wheel speed sensor.
Old Nov 16, 2019 | 01:01 PM
Justa02TJ's Avatar
Justa02TJ
���� I’ll crawl under the truck later today and check. Thanks for the quick response.
Old Nov 19, 2019 | 08:11 PM
03griz's Avatar
03griz
oops wrong thread.
Last edited by 03griz; Nov 20, 2019 at 07:14 AM. Reason: posted to incorrect thread.
Old Nov 19, 2019 | 08:31 PM
TeddyD's Avatar
TeddyD
These are all warnings that a brake related. Something tells me it might be a bad connection near the emergency brake pedal. This was a common issue before and is what others recommended for me when I had something similar happen. My alerts went off every time I touched the brake and include ABS faults. Turned out to be a brake sensor and the faulty connection near the e-brake.
Old Nov 20, 2019 | 06:30 AM
swlakingranch's Avatar
swlakingranch
I had these same messages pop up. It was due to a loose nut holding on the pitman arm.
Old Nov 20, 2019 | 06:35 AM
Spoojr's Avatar
Spoojr
Same issue here with a 2017 6.7. Dealer can’t find the issue, and it only does it randomly so I can’t duplicate it for the dealer. I don’t have the thread off hand, but you can search for truck errors and probably find it. There have been several threads on it.
Old Nov 21, 2019 | 10:50 PM
Jk22's Avatar
Jk22
I have a 2019 6.7 f250 platinum. My dash started flashing these same things a week ago. It happened about 6 different occasions. I took it to the dealer today. There is a tsa on this issue. The dealer called ford and said there is a module under the hood that may not be tightened enough after production. He said there are 3 modules. They unplugged all 3 and when he unplugged the second one he said the dash flashed all the warnings. He snapped it back into place firmly. So far so good. He said if it doesn't fix the problem they have to go through each individual connector in the module that is not getting connection properly, aka loose.
Old Nov 22, 2019 | 01:49 AM
Spoojr's Avatar
Spoojr
I’m not familiar with a TSA, did you mean TSB? Either way, do you happen to have the number to it? (Possibly written on your paperwork they gave you when you picked it up?) My dealer is not familiar with it, and is pretty much stumped and not helpful. My warranty is up next month, so it would be great to have this addressed.
Old Nov 22, 2019 | 03:09 AM
Jk22's Avatar
Jk22
I meant TSB, and I was just in and out so no paper work. I can call tomorrow and see if I can find out something. I watched them work on the truck from the sitting area and everything was done with the hood popped. I know that is very vague. The guy there explained everything a lot better than I did, but he did say he unplugged them and just snapped then in tight.
Old Nov 22, 2019 | 06:41 AM
Spoojr's Avatar
Spoojr
If you get around to it, that would be great. I’ve had to bring it printed TSBs to the dealer before when they had never heard of what I was describing. I guess they don’t search for them when I bring it in.
Old Nov 22, 2019 | 07:08 PM
Justa02TJ's Avatar
Justa02TJ
Update:
I haven’t had the issue since the date of the original post, and I’m thinking I corrected the problem. After the 1st post, as I was driving the fwy, I noticed the front axle felt like it was drifting then I hit a rough patch of road and got awful feedback from the steering wheel (DW) for the 1st time ever in this truck.
After getting it home, crawled underneath and checked my track bar bolt and it was loose, nowhere near 405 lbf-ft. I torqued it when I installed the BDS leveling kit but must have loosened up.
After re-torquing the trackbar and 1 week later no more warning messages.
Im guessing the sensors picked up issues caused by the front axle shifting and thus the warnings.
Mike
irocdupi
6.2L V8
Jul 26, 2017 02:14 PM
Badass69
2009 - 2014 F150
16
Jan 13, 2017 11:06 PM
chrowen
2009 - 2014 F150
Jan 4, 2016 03:31 PM
Ammie
Jun 22, 2010 10:20 PM
Dazz
2004 - 2008 F150
16
Jul 5, 2005 07:31 PM
