Transmission
Old Nov 15, 2019 | 08:42 AM
Randall 5377's Avatar
Randall 5377
Transmission
Hi I have a 2003 f350 7.3. I'm having transmission problem. My truck ran fine parked it went out to leave only had 1st and reverse. Hooked it the truck to a scan tool the only code that it showed was p0475 I replaced that sensor and tube truck went into drive with no problem. Once the truck warmed up I lost everything but 1st and reverse again. Help
Old Nov 15, 2019 | 08:51 AM
FordTruckNoob's Avatar
FordTruckNoob
P0475 is for the EBPV actuator, not the EBP sensor (EBPS). Is your EBPV jammed shut?
Old Nov 15, 2019 | 09:08 AM
Randall 5377
I haven't checked
Old Nov 15, 2019 | 09:11 AM
ajbrown208's Avatar
ajbrown208
fluid level? visual inspection of fluid on dip stick? ATF leaks anywhere? Lets start simple.
Old Nov 15, 2019 | 09:18 AM
Randall 5377
Fluid is full
Old Nov 15, 2019 | 09:34 AM
ajbrown208's Avatar
ajbrown208
Unhook shift solenoid at the transmission. Start the engine and shift it through all the gears. Its doesn't have to move. Turn off vehicle and pull the codes.
Unklebob
Apr 2, 2015 11:49 AM
Graygeorge
Aug 3, 2009 12:04 PM
sf0606
Sep 14, 2006 06:08 AM
mymechanic'sanidiot
1983 - 2012 Ranger & B-Series
Jul 14, 2006 04:39 PM
vlietracer64
Mar 10, 2005 11:56 AM
