Sponsored by: Real Truck
VIN decoder
Old Nov 15, 2019 | 06:40 AM
CHRNGOE's Avatar
CHRNGOE
VIN decoder
I am trying to do a VIN lookup for a truck i just bought. I have tryed the decoder i found in this forum, but it says it is an invalid VIN??? Can anyone help?
Old Nov 15, 2019 | 07:39 AM
Just Strokin's Avatar
Just Strokin
You can go here and download the Ford VIN Guide for your model year truck/car/etc.
https://www.fleet.ford.com/partsandservice/vin-guides/
Old Nov 15, 2019 | 08:12 AM
CHRNGOE's Avatar
CHRNGOE
Thanks that helps some, but really looking to get down to the build/spec/option sheet. Is this possible?
Old Nov 15, 2019 | 08:43 AM
brian42's Avatar
brian42
Veteran: Navy
Not sure if any of them are what you're looking for but here's a thread from a couple of years ago with some links:
https://www.ford-trucks.com/forums/1...ild-sheet.html
Old Nov 15, 2019 | 11:25 AM
Just Strokin
Ford took the window stickers offline a few years ago and also limited any info from ETIS site. You might take the VIN to a dealer and get some info you seek.
Old Nov 15, 2019 | 07:28 PM
96_F250_Deezal's Avatar
96_F250_Deezal
Ford ETIS system doesnt recognize this VIN either.
Old Nov 15, 2019 | 07:35 PM
96_F250_Deezal
The VIN decoder web page recognizes the VIN, but doesnt break it down very well. Most Ford systems will only go back 8-10 yrs.
https://www.vindecoderz.com/EN/check...NW21SBYEE57248
Old Nov 15, 2019 | 07:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I cannot decode all of this* .. but 1981 thru today 17 digit VIN's have the same sequence.
1FT = FoMoCo USA - Ford Truck - Complete Vehicle.
N = Class ? Hydraulic Brakes - the rest is the Gross Vehicle Weight Rating range.
W21 Series code = F250 but what follows, I dunno.
S = Engine code.
B = Check digit, FoMoCo use only.
Y = 2000.
E = Mahwah NJ Assembly Plant (U = Louisville).
E57248 = 2000 Numerical Sequence of Assembly, the trucks specific serial number.
Over the past 13 years, I've decoded over 1,000 VIN's on FTE and if my *microfiche viewer bulb wasn't burned out...I could decode this too.
My 1990/2001 Ford Truck Parts Catalog is on microfiche.
Old Nov 15, 2019 | 08:15 PM
Just Strokin
This is the ETIS report for my truck prior the time that Ford took most all their data offline. Unless you can get someone to get an ETIS printout, you are probably not going to be able to get all the data you seek.
The ETIS would give the following info, which is the info he seeks....
Old Nov 15, 2019 | 08:52 PM
96_F250_Deezal
ETIS system still works. I logged in and ran the VIN.
Old Nov 16, 2019 | 04:38 AM
Just Strokin
Why didn't you provide the ETIS info if it still works?
Old Nov 16, 2019 | 09:51 AM
96_F250_Deezal
As I mentioned, the VIN didnt show up in ETIS. most Ford systems only go back 8-10 yrs.
Old Nov 16, 2019 | 11:50 AM
Just Strokin
The reason it didn't show up for you is the VIN above that was used is wrong.
1FTNW21SBYEE57248
Actual VIN is
1FTNW21S8YEE57248
Old Nov 16, 2019 | 01:59 PM
96_F250_Deezal
well, ETIS has me locked out right now due to a password change and now it wont recognize new password I created.
You are correct about the VIN, I know it was 8 not sure how B got in there.
Old Nov 19, 2019 | 10:08 PM
96_F250_Deezal
Ok, ETIS access is back .. and I ran the VIN for the build information. Wonder if you can read this...
66duke
Mar 28, 2016 03:52 PM
flynbya2
May 3, 2011 03:29 PM
onlya4.9
Oct 29, 2010 12:11 AM
newfordguy77
Aug 8, 2007 01:44 PM
stupidmonkey
Sep 6, 2005 03:35 PM
