Crank no start
Old Nov 14, 2019 | 09:10 PM
Fordguy1974's Avatar
Fordguy1974
Crank no start
I have 92 f150. Crank no start. I have did new plugs and wires,distributor,coil, will attempt to start for a few secs after alot of starter fluid. I have an ignition control module for it. Installing tomorrow. Any help will be appreciated.
Old Nov 15, 2019 | 09:05 AM
rla2005's Avatar
rla2005
If the engine fires off with starting fluid that means you spark. Absolutely no reason to install a new Ignition Control Module (ICM) IMHO.
Does the fuel pump energize for 1-2 seconds when cycling the key from Off to Run?
Old Nov 15, 2019 | 06:03 PM
Fordguy1974
1992 crank no start
Engine does start. Seems to want too. If u spray starter fluid in throttle body after a while it seems to try to start for a few seconds but still doesn't.
Old Nov 15, 2019 | 07:45 PM
jas88's Avatar
jas88
Have you checked for spark? Have you checked compression? Either the ignition system is at fault, or it has jumped time, is my opinion.
Old Nov 16, 2019 | 11:00 AM
rla2005's Avatar
rla2005
So when did the no start issue begin? Any other service work been done recently?
Old Nov 16, 2019 | 12:21 PM
Fordguy1974
Crank no start.
It was running ok. Turned it off one day did not start back. My son was playing with tank switch but I can here pumps in both positions. I get fuel to rail .
Old Nov 16, 2019 | 05:06 PM
joey2fords's Avatar
joey2fords
"Does the fuel pump energize for 1-2 seconds when cycling the key from Off to Run?"
what's the answer to this question ?
Old Nov 16, 2019 | 06:14 PM
Fordguy1974
Crank no start
Yes front and back tank both energize.i have checked both.
Old Nov 16, 2019 | 06:36 PM
rla2005's Avatar
rla2005
More concise question: Do they energize then shutoff after 1-2 seconds?
They should.....
Fordguy1974
1997 - 2003 F150
Nov 14, 2019 08:01 PM
Yit96
Aug 3, 2019 09:42 PM
Ken N Tx
3.8 & 4.2L V6
Jan 7, 2016 04:33 AM
just1me
Nov 1, 2005 03:58 PM
