Bad grounds....
Old Nov 17, 2019 | 10:20 PM
meangreen92's Avatar
meangreen92
The old glass fuses seem more susceptible to that corrosion than do the blade-style fuses.
Old Nov 18, 2019 | 01:13 AM
1TonBasecamp's Avatar
1TonBasecamp
Yes, definitely. The new ones still get discolored and build up some gunk on them, but seems not to creep into the actual contact areas that always seem to show as clean shiny strips.
I wonder if it's strictly due to the design, or if the materials used are better suited?
Paul
Old Nov 18, 2019 | 06:03 AM
Tedster9's Avatar
Tedster9
Originally Posted by 1TonBasecamp
This process of just removing and replacing breaks a "skin" of resistive corrosion for lack of a better word, and lets things work closer to their potential.
This is actually true of every ground or ground & start or battery cable connection, SAE bullet connector, everything. Every electrical connection is a potential failure point. Meaning, the connection will start to degrade from the git go and eventually, fail. Dissimilar metals has something to do with this. Add to that the hardware or bolts securing connections tend to loosen a bit over time, too. Physically tight isn't necessarily electrically tight enough. The beauty is, everybody thinks yer a genius when ya fix their $&@t. LOL.
SemperFi_YEMX
Sep 8, 2019 08:49 AM
Tigger!
May 19, 2016 07:15 PM
KidWithTheLoudFord
Mar 31, 2016 07:55 PM
curt.farmer712
Dec 23, 2010 10:52 PM
Stoney
Sep 14, 1999 11:28 PM
