Still wont crank
Old Nov 12, 2019 | 08:01 PM
Will Joyce's Avatar
Will Joyce
Still wont crank
Have replaced everything that I know of - starter solenoid /relay, ignition key lock switch , Starter switch
the only thing that has not been replaced is the actuater rod under the steering wheel .
went to advance & got a steering wheel puller --bolt hole did not line up & none were the right thread design
Question does anyone know of an auto parts store that would have one to fit a 87 f 150 that I could rent , not buy
Old Nov 12, 2019 | 08:04 PM
Will Joyce's Avatar
Will Joyce
Oh I forgot --the starter works --I get it started now by jumping the small solenoid post to the hot battery post
think I will just hot wire a start button ( maybe use a horn button ) ?
Old Nov 12, 2019 | 08:57 PM
88n94's Avatar
88n94
Have you tried adjusting the ignition switch closer to the steering wheel? Also have you tried bypassing the clutch safety switch switch as suggested under #22 in your other thread?
Old Nov 12, 2019 | 09:28 PM
Will Joyce's Avatar
Will Joyce
yes . have tried both of the above
DG93
Aug 25, 2015 04:48 PM
Woodsman_30350
Jun 6, 2011 12:27 PM
kona72
Aug 31, 2007 09:26 PM
trooperkelly
Jul 23, 2006 09:15 PM
marrsman
Dec 25, 2004 07:39 AM
