Need help with Ignition
Old Dec 22, 2004 | 08:00 PM
marrsman's Avatar
marrsman
8th Gear
I have a 1994 F-150 with tilt steering wheel. It will not turn over when I try to start it. However I can jump it at fenderwell and get it to run. I have replaced starter, fender solenoid, ignition switch and neutral safety switch on side of transmission but still no luck. I have voltage to starter but willl not engage starter from cab, ( ignition switch) . Any Ideas. Thanks
Old Dec 23, 2004 | 06:58 AM
guzzler96's Avatar
guzzler96
Lightbulb
I would suspect the lower actuator may be broken. Very common problem even on newer trucks. Take a look at these post and follow all internal links in all the posts. There will be at least (5) links. You should be able to get most of it from this. If you have specific questions just post back.
https://www.ford-trucks.com/forums/s...d.php?t=313212
https://www.ford-trucks.com/forums/s...d.php?t=319861
guzzler96
Old Dec 23, 2004 | 07:34 AM
moondogg's Avatar
moondogg
wire
ohm out the wire to the sol. from ign. switch to see if its broken somewhere.
if not maybe you got a bad switch. moondogg
Old Dec 24, 2004 | 07:18 PM
marrsman's Avatar
marrsman
8th Gear
Need help with ignition
Thanks, found upper plastic rod broken, couldnt find one locally so I temp bypassed with universal starter switch from pep boys, thanks for help in diagnosing it. Wish I found this forum sooner.
Old Dec 25, 2004 | 07:39 AM
guzzler96's Avatar
guzzler96
Thumbs up
No problem. There is a wealth of info. floating around on this forum. I think that the actuator is pobably a dealer only part. If you need more help just post.
guzzler96
