Sponsored by: Kumho
Removing new wheels
Old Nov 10, 2019 | 06:27 PM
wylecoyote's Avatar
wylecoyote
Removing new wheels
I was going to install y leveling kit this weekend, and I could not get the damn front wheels off. Anyone have a trick to removing them just shy of beating on the wheel with a BFH.
Thanks,
Old Nov 10, 2019 | 06:32 PM
seville009's Avatar
seville009
spray pb blaster or wd40 where the rim meets the hub and let it soak in. or loosen the lug nuts a bit and drive the truck back and forth a few feet
before you put the tires back on, spray wd40 on the hub; stops rust from forming and the wheel should be easy to get off next time
Old Nov 11, 2019 | 11:18 AM
f5fordgirl's Avatar
f5fordgirl
Hold a piece of 2x4 against the rim, then hit it with the hammer, won't mess up the rim, if alum wheels they tend to oxidize on the steel hub.
Old Nov 11, 2019 | 06:17 PM
wylecoyote's Avatar
wylecoyote
Thank you both, I will give them a try. Its brand new, so I cant see corrosion sitting in already.
Old Nov 12, 2019 | 08:48 AM
the_hetz's Avatar
the_hetz
It happens *fast* with steel contacting aluminum.
Anti-seize the mating surfaces before putting them back together.
FordMan007
All Things Towing
Jul 5, 2021 07:08 AM
dethpulse
Aug 15, 2018 07:23 PM
darenp
Large Truck
Apr 1, 2016 12:01 PM
djanzen
Aug 11, 2010 09:14 PM
QwkTrip
Aug 8, 2009 12:35 PM
