Sponsored by: Kumho
After market wheels?
Old Aug 2, 2010 | 09:41 PM
djanzen's Avatar
djanzen
Why is it that the after market wheels never use the flange nut for the super duty wheels? It is a superior way of wheel tightening, The studs do not support the weight of the vehicle. Any info out there?
Old Aug 7, 2010 | 01:09 PM
djanzen's Avatar
djanzen
nobody has an opinion?
Old Aug 11, 2010 | 08:51 PM
Lou Braun's Avatar
Lou Braun
Hub centric wheels are vehicle specific. It is cheaper to make aftermarket wheels that use the wheel lugs to locate the wheel.
The stock Ford hub centric wheels are designed for heavy-duty truck use. Their only real disadvantage is that they are a bear to remove if the hub section gets rusty. Many of us forget to put anti-seize lube on the hub when installing or rotating tires. We cuss ourselves later.
Lou Braun
Old Aug 11, 2010 | 09:14 PM
djanzen's Avatar
djanzen
Lou Braun
Are not all wheels vehicle specific? cant put a SD wheel on a f150/ dodge / gm? I just think that for the weight alot of us carry, dot should make them do this!
